Relativity & Gravity: Does Potential Energy Increase Mass?
  • Context: Graduate
  • Thread starter Thread starter andypandy2020
    Gravity Relativity
The discussion revolves around the relationship between gravitational potential energy (GPE) and mass in the context of relativity. Participants explore whether an increase in GPE contributes to an increase in effective mass, and the implications of this relationship within relativistic frameworks.
  • Some participants suggest that kinetic energy increases effective mass according to E=mc², and question if GPE similarly affects mass.
  • Others argue that the term "relativistic mass" is outdated, and modern physics typically refers to "invariant mass," which may not account for GPE.
  • One participant posits that if GPE increases mass, it could lead to a paradox where GPE continues to increase, suggesting GPE does not contribute to invariant mass.
  • Another participant states that potential energy is meaningless in relativity, leading to questions about its relevance to mass.
  • Some assert that potential energy is dependent on the relative distance between particles, complicating its definition in a relativistic context.
  • One viewpoint emphasizes that while potential energy may be difficult to define in general relativity, the rest mass of an object changes with its position, linking mass changes to potential energy changes under certain conditions.
  • Another participant clarifies that potential energy pertains to a system rather than an individual object, which complicates attributing GPE to single objects.
Participants express multiple competing views regarding the role of gravitational potential energy in relation to mass. There is no consensus on whether GPE contributes to invariant mass or how it should be defined in relativistic terms.
Participants note limitations in defining potential energy within general relativity, particularly in time-dependent metrics, and the challenges of attributing potential energy to individual objects versus systems.
andypandy2020
As it is quite often shown, when an object is moving, it's kinetic energy causes an increase in its effective mass in accordance with E=mc^2.
When considering other "forms" of energy, such as gravitational potential energy, does this also cause an increase in effective mass, albeit very small?
Hi andypandy2020, welcome to PF
What you are describing here is called "relativistic mass" and it is no longer in common use amongst modern physicists. Physicists usually reserve the term "mass" to mean the "invariant mass".
Ok that's fine.
What I was getting at though was that if there is an increase in an object's mass when its GPE increases, then would this not increase its GPE further? This, however, cannot be right, and so it would imply that for some reason GPE does not contribute to invariant mass.
In Relativity, the term potential energy is meaningless.
Why is that, surely an object in a field must have potential energy, and then why wouldn't this contribute to its invariant mass? Even if this term is very small why does it not cause a problem of the mass and potential energy growing?
Potential energy is a function of the relative distance between two particles. Since the distance is not a relativistic invariant, we cannot uniquely assign a potential energy function. Remember that the gravitational potential energy of a body near the Earth's surface is actually the potential energy of the system body-Earth and depends on their mutual separation.
I wouldn't go so far as to say that GPE is meaningless. In a stationary spacetime you can certainly make a potential that reduces to the Newtonian potential in the appropriate limit. However, in general GPE and even mass are difficult to define in GR. Here is a link that goes over some of the issues:
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
No .. Potential Energy is not a true property of the object ..it is just a mathmatical trick to make the law of concervation of energy valid locally by taking the work which will be done in the future as a property of now. This is true in both Newtonian and Relativistic Mechanics
You seem to be confused about what the term energy means. Go ahead and look up classical definition.
At any rate, while actual potential might be a bit difficult to define in GR, especially in time-dependent metric, the rest mass of an object definitely does change with position of the object. Under linearized gravity, where GPE is fully meaningful again, this mass change corresponds perfectly to potential energy change.
This is true for a system of density of particle but not for single object
To an object in a point-moment in space-time there is no potential energy
This is a good point. Potential energy pertains to a system and really cannot be attributed to an individual object within the system.
  • · Replies 25 ·
  • · Replies 102 ·
  • · Replies 62 ·
  • · Replies 19 ·
  • · Replies 28 ·
