Does Function Composition Automatically Restrict Domains to Match Ranges?
  • Context: Graduate
  • Thread starter Thread starter Rasalhague
    Composition Functions
The discussion centers on the composition of functions and whether it automatically restricts the domain of the outer function to match the range of the inner function. It is established that composition is typically defined only when the range of the inner function is contained within the domain of the outer function. This means that for a function to have an inverse, it must be bijective. The conversation also touches on the implications for the chain rule in calculus, emphasizing that additional conditions may be necessary for its general applicability.
  • Understanding of function composition in mathematics
  • Knowledge of injective and bijective functions
  • Familiarity with the chain rule in calculus
  • Basic concepts of category theory related to functions
  • Study the properties of injective and bijective functions in detail
  • Learn about the implications of the chain rule in different contexts
  • Explore category theory and its definitions of composition and inverses
  • Investigate the relationship between functions and relations in mathematics
Mathematicians, educators, and students seeking a deeper understanding of function composition, inverses, and their applications in calculus and category theory.
Rasalhague
Is composition of functions defined in such a way as to automatically restrict the domain of the outer function, if need be, to the range (image) of the inner one, so that it's always possible to write [itex]f^{-1} \circ f\left ( x \right ) = x[/itex], providing [itex]f[/itex] is an injective function? Or is composition only defined for functions that are already compatible in the sense that the domain of the outer function must be the range of the inner one, so that [itex]f[/itex] must be bijective to have an inverse?
The section Inverses in higher mathematics here says definitely the latter, but is the former idea often used in practice? For example, does this statement of the chain rule for one variable need extra caveats for
[tex]\left ( f \circ g \right )' = \left ( f' \circ g \right ) \cdot g'[/tex]
to be true in general? Specifically, would it only be true if [itex]f[/itex] was restricted to the domain of [itex]g[/itex] (rather than the condition being merely that [itex]f[/itex] is defined on an interval of which the range of [itex]g[/itex] is a subset), and differentiable on the range of [itex]g[/itex]?
Mathematics news on Phys.org
Usually/in practice: the composition of two functions is defined if the image ('range') of the one is contained in the domain of the other.
But in some (formal) contexts, it is what you say: e.g. in category theory the composition of two arrows is defined iff the codomain of the one is equal to the domain of the other (in an abstract category, the domain and codomain of arrows are not sets, so this makes sense).
As often, people are a bit sloppy, or - depending on your exact definition of 'function' - it makes no difference: any function f:X\to Y can be regarded as a function f:X\to Y' where Y' is any set that contains Y, and we usually don't distiguish them explicitly. [A lot of your questions seem to be about mathematicians' sloppiness :)]
Note that this occurs already at the level of relations: a relation R from X to Y is subset of the product X x Y. But such an R is at the same time a subset of X' x Y' for any X' resp. Y' that contains X resp. Y, so it is at the same time a relation from X' to Y'. Unless you define it as an ordered triple (X,Y,R), and then it becomes sloppiness to ignore the difference.
The composition of two functions is a special case of the composition of two relations (recall that a function is by (the usual) definition a special kind of relation): Let X,Y,Z be sets, R a relation from X to Y, and S a relation from Y to Z. In other words, R is a subset of X x Y, and S is a subset of Y x Z. Then their composition is
[tex]S\circ R:=\{(x,z)\ |\ \exists y\in Y: (x,y)\in R\text{ and }(y,z)\in S \}\subseteq X\times Z,[/tex]
which is a relation from X to Z. This makes sense for any two such relations. This compostion might be empty. Again, you could be more flexible about the codomain of R and domain of S; why wouldn't we allow R and S to be any two relations whatsoever, and define
[tex](S\circ R)_{new}:=\{(x,z)\ |\ \exists y\in \text{codomain}(R)\cap\text{domain}(S): (x,y)\in R\text{ and }(y,z)\in S \}\subseteq X\times Z[/tex]?
Of course, in the context of functions, we have to require more if we want the composition relation to be a function. Indeed, suppose R:X\to Y and S:Y'\to Z are any two functions. For the relation [itex](S\circ R)_{new}[/itex] to be a function from X to Z, we need for every x in X the existence of a unique z in Z such that [itex](x,z)\in(S\circ R)_{new}[/itex]. Fix x in X. As R is a function, there is a unique y in Y such that (x,y)\in R. So this is the only y we can consider in the definition of [itex](S\circ R)_{new}[/itex]. And now we need a unique z in Z such that (y,z)\in S. As S is a function, this happens iff y is in the domain Y' of S. So with this definition, the relation composition of two functions R:X\to Y and S:Y'\to Z is a function (from X to Z) if and only if Y' contains Y. Yay, this is in agreement with what I said is done in practice.
I recommend against the use of the notation f^{-1} for the left inverse if it is not also the right inverse, i.e. if the function is injective but not surjective.
I think this depends on your definition of 'inverse' rather than of 'composition'. Usually, f:X\to Y is called invertible if there is a function g:Y\to X such that f\circ g is id_Y and g\circ f=id_X. (This is also the general definition in category theory.) You could of course just replace Y with f(X) in this definition.
