This should be a simple problem to solve but im just not getting it
  • Context: Undergrad
  • Thread starter Thread starter mathrocks
The discussion revolves around solving a differential equation using the method of undetermined coefficients. Participants are attempting to determine the coefficients A, B, C, and D in the particular solution of the equation without given initial values, leading to uncertainty in their calculations.
  • One participant presents their work on the differential equation and expresses uncertainty about the correctness of their coefficients A, B, C, and D.
  • Another participant questions the sign of a term in the equation, suggesting it should be +2Bt instead of -2Bt.
  • A later reply asks for the calculations of the coefficients to verify the results and expresses doubt about the correctness of the previous calculations.
  • One participant claims to have calculated D as 116/9 and notes that the earlier mistake regarding the sign of +2Bt affected the values for C and D.
  • Another participant points out a perceived mistake in the calculations related to the coefficient of B being negative.
Participants express differing views on the correctness of the calculations and the signs of terms in the equations, indicating that multiple competing views remain and the discussion is unresolved.
There are unresolved mathematical steps and dependencies on the correctness of earlier calculations, particularly regarding the signs of terms and the values of coefficients.
mathrocks
I'm given an equation to solve and I need to use the "method of undetermined coefficients" all I need to find is A,B,C,D I'm not given any initial values so I can't solve the entire thing. This is what I have but I'm not sure if it's correct or not. Thanks for any help...
Equation: 2y''+5y'-3y=-2t^3+4t^2
My work:
2r^2+5r-3=0
r=1/2, r=-3
Yh=C1e^(1/2t) + C2e^(-3t)
Assume Yp=(At^3+Bt^2+Ct+D)
yp'=3At^2-2Bt+C
yp''=6At-2B
plugging the derivatives into the original equation I get: 12At-4B+15At^2-10Bt+5C-3At^3-3Bt^2-3Ct-3D=-2t^3+4t^2
Solving for A I get: -3At^3=-2t^3 -> A=2/3
Solving for B I get: 10t^2-3Bt^2=4t^2 -> B=2 ?
Solving for C I get: 8t-20t-3Ct=0 -> C=-4 ?
Solving for D I get:-8-20-3D=0 -> D=-28/3 ?
The "?" are the ones I don't know are right. I'm pretty sure the value for A is right though. Also, I plugged in the values for A, B, C, D into the equation as I solved for them, incase you were wondering where some of the numbers came from...
I really need help with this, so anything you can do will be greatly appreciated.
"Assume Yp=(At^3+Bt^2+Ct+D)
yp'=3At^2-2Bt+C
yp''=6At-2B
plugging the derivatives into the original equation I get: 12At-4B+15At^2-10Bt+5C-3At^3-3Bt^2-3Ct-3D=-2t^3+4t^2"
Why -2Bt? it should be +2Bt
Once you've done this, enter these expressions into your rleft-hand side; gather together EVERY t^3 term, t^2-term and so on.
Only then set them equal to the corresponding terms on your right-hand side
yp'=3At^2-2Bt+C
yp''=6At-2B
Awesome, thanks a lot. Did you get D=116/9?..if you worked it out.
I didn't.
Frankly, I'm a bit dubious about how you proceeded further on; could you post your calculations of the coefficients?
(Or alternatively, check that your "solution" actually IS a solution of your diff.eq.)
arildno said:
I didn't.
I plugged in the values of A, B, C, D into the equation and I get 0=0.
For the calculation of B I did: 10t^2-3Bt^2=4t^2 -> B=2
For the calculation of C I did: 8t+20t-3Ct=0 -> C=28/3
For the calculation of D I did: -8+140/3-3D=0 -> D=116/9
The mistake you pointed out earlier about +2Bt only affected the answers for C and D.
Ok, I didn't read what you wrote carefully enough..:redface:
yp'=3At^2-2Bt+C
yp''=6At-2B
I think there's a fairly obvious mistake here! How did the coefficient of B get to be negative in these last two?
