Stuck trying to integrate a differential equation
The discussion revolves around solving a differential equation of the form dy/dx = a^2/((x+y)^2), where a is a constant. The goal is to express the solution in the form x = f(y).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to integrate the equation using a substitution u = x + y and expresses concerns about rearranging the result into the desired form. Some participants question the correctness of the integration steps and suggest alternative approaches, including integration by parts.
Participants are actively engaging with the problem, offering different methods and questioning the validity of each other's approaches. There is no explicit consensus on the correct method or outcome, but several lines of reasoning are being explored.
There are indications of confusion regarding the integration process and the use of integration by parts. The original poster expresses uncertainty about the assumptions made during the integration and the manipulation of terms.
dooogle
dy/dx=a^2/((x+y)^2)
express answer in the form x=f(y)
let u=x+y
du/dx=1+dy/dx
du/dx=1+(a^2)/(u^2)
int(du/(((a^2)/(u^2))+1))=int(a^2 dx)
after integration substituting back in for u gives:
(-1/(2a))*arctan(a/((x+y)^2))=(a^2(x+c))/((x+y)^3)
i don't know how to rearrange into the form f(y)=x
please could you let me know if i have made mistakes and if not could u tell me how to rearrange arctan(a/(x+y)^2) into a form where x and y are separable
thanks for your time
dooogle
If I've interpreted your equations correctly (try using latex code, it is a lot simpler to read), it seems to me that you've done an error when simplifying the expression that is to be integrated. I get something like
[tex]\frac{du}{dx}=1+ \frac{a^2}{u^2}[/tex]
[tex]\Leftrightarrow \frac{du}{dx}=\frac{u^2 + a^2}{u^2}[/tex]
[tex]\Rightarrow \int \frac{u^2 du}{u^2 + a^2} = \int dx[/tex]
This integrand doesn't seem to agree with yours.
cheers for the response
ive tried integrating:
u^2/((u^2)+(a^2))du
by parts but the answer i get is not the same as what i get when i use wolfram online integrator
is it correct to try integration by parts? where the equation is
int(f(u)g'(u))=f(u)g(u)-int(f'(u)g(u)du)
taking f(u)=1/((u^2)+(a^2)) g'(u)=u^2
so f'(u)=-2u/((u^2)+(a^2))^2 g(u)=(u^3)/3
so integral equals
(u^3)/3((u^2)+(a^2))-int((u^3)/3*-2u/((u^2)+(a^2))^2))
=(u^3)/3((u^2)+(a^2))-int((-2u^4/(3((u^2)+(a^2))^2)))
which does not seem to work
i apologise for not using latex i tried to but it didnt work
thank you for your time any help would be much appreciated
cheers
dooogle
Try using the opposite order. Differentiate u2 and integrate 1/(u2+a2).
ok so i set f(u)=u^2
f'(u)=2u
g'(u)=1/(u^2+a^2)
g(u)=ArcTan[u/a]/a
applying integration by parts formula gives
(u^2)*ArcTan[u/a]/a-int(2uArcTan[u/a]/a du)
which gives a*arctan(u/a)-x=int a^2 dx
arctan(u/a)=ax+c
so (u/a)=tan(ax) +tan(c)
subbing back in for x+y gives
x+y=a*tan(ax)+a*tan(c)
x=a*tan(ax)+a*tan(c)-y
please could u let me know if i have integrated incorrectly
or if i have made a mistake elsewhere
thanks very much for your time
dooogle
You integrated by parts incorrectly. You should get 2u/(u2+a2) as the second integral, not what you have.
i have attempted it with a different method since the last method did not seem to supply the right answer please could someone tell me where i am going wrong with this new method:
dy/dx=(a^2)/((x+y)^2)
where a^2 is a constant and the answer must be expressed in the form x=f(y)
dy/dx=(a^2)/((x^2+2*x*y+y^2)
let u=y/x
dy/dx=(a^2)/((x^2+2u*x^2+u^2*x^2)
dy/dx=(a^2)/(x^2(1+2u+u^2)
du/dy=(du/dx)*(dx/dy)
du/dx=-y/(x^2)
dx/dy=(x^2(1+2u+u^2)/(a^2)
so du/dy=-y*((1+2u+u^2)/(a^2))
int(1/((u+1)^2))du= -1/a^2*int(y)dy
-1/(u+1)= -y^2/(2*a^2)+[here i am unsure whether the +c is multiplied by -1/a^2] assuming it is not gives:
-1/(u+1)= -y^2/(2*a^2)+c
substituting back for u gives
-1/((y/x)+1))=-y^2/(2*a^2)+c
[not sure if this is next step is right]
-(x/y)-1=-y^2/(2*a^2)+c
-x-y=(-y^3)/(2*a^2)+c
x=(y^3)/(2*(a^2))-y+c
any help would be much appretiated
dooogle
