How Can I Use the RGD Sequence to Isolate the Fibronectin Receptor?
  • Thread starter Thread starter nautica
The discussion focuses on isolating the fibronectin receptor using the RGD sequence, a specific amino acid sequence known for its role in receptor binding. Nautica suggests employing affinity chromatography for this purpose, detailing a method that involves attaching the ligand to biotin or agarose beads, incubating with the receptor, and using salt solutions to wash away non-specific bindings. This process is essential for obtaining a purified fibronectin receptor, which is crucial for various biochemical applications.
  • Understanding of affinity chromatography techniques
  • Knowledge of protein solubilization methods
  • Familiarity with receptor-ligand interactions
  • Basic laboratory skills in centrifugation and solution preparation
  • Research advanced affinity chromatography techniques for receptor isolation
  • Learn about biotinylation methods for protein labeling
  • Explore solubilization techniques for membrane proteins
  • Investigate the effects of salt concentration on protein binding and elution
This discussion is beneficial for molecular biologists, biochemists, and researchers involved in protein purification and receptor studies, particularly those focusing on fibronectin and its interactions.
nautica
I have found the a.a. sequence in fibronectin that attaches to the fibronectin receptor.
I have concluded RGD. How can I use this to isolate the fibronectin receptor?
Thanks
Nautica
Biology news on Phys.org
You could use affnity Chromatography isolation.
http://www.bio.davidson.edu/Courses/Molbio/MolStudents/spring2003/WoodW/affchrom1.html
Or a process derive from affinity Chromatography which can be done in a tube.
1- You attach the ligand to either to biotyne or agarose beads.
2- You mix the potential receptor with the attach ligand and incubate in a solution and at a temperature that is good for binding.
2b- solubilize the protein if it is a membrane protein. This could also occur before step 2.
3- You then treat with low salt solution to remove unspecific binding, you centrifuge and remove the supernatant and keep the pellet, and treat and centrifuge again until you think you have mostly only the desired receptor.
4- Then you treat with high salt solution and other steps to remove the binding and centrifuge but in this case you keep the supernatant.
This is the steps we use to isolate Hb-binding receptors
http://www.geocities.com/nivenlab/Hb_AI.pdf
  • · Replies 50 ·
10K
  • · Replies 31 ·
