Hawking Radiation seems contrary to black hole dynamics
The discussion revolves around the concept of Hawking Radiation and its implications for black hole dynamics. Participants explore the mechanisms of particle-antiparticle creation at the event horizon, the nature of energy associated with these particles, and the conditions under which particles can escape or enter a black hole. The conversation touches on theoretical interpretations and the challenges of conveying complex physics concepts without mathematical rigor.
  • One participant describes Hawking Radiation as involving a particle escaping the event horizon while its antiparticle enters the black hole, leading to energy release and black hole evaporation.
  • Another participant asserts that nothing escapes from the black hole, emphasizing that vacuum fluctuations occur just outside the event horizon, and questions the idea of annihilation negating particles inside the black hole.
  • A different viewpoint suggests that annihilation does not equate to destruction but rather the formation of new particles, adhering to the conservation of energy.
  • One participant highlights the role of negative-energy particles in the context of Hawking Radiation, arguing that the process is not simply about antimatter falling into black holes.
  • Concerns are raised about the equal likelihood of positive and negative energy particles entering the black hole and whether they would cancel each other out, questioning the dynamics of particle behavior at the event horizon.
  • Clarifications are made regarding the nature of negative-energy particles and their inability to exist outside the event horizon for extended periods, which impacts the energy exchange dynamics with the black hole.
Participants express differing views on the mechanisms of Hawking Radiation, the roles of particles and antiparticles, and the implications for black hole energy dynamics. No consensus is reached, and multiple competing interpretations remain present.
Participants note the difficulty in accurately describing advanced physics concepts without mathematical frameworks, particularly in relation to Hawking Radiation. There are unresolved questions regarding the assumptions about particle behavior and the implications of energy conservation.
jaketodd
My understanding of Hawking Radiation is that a particle and anti-particle form at the event horizon, the particle escapes, the anti-particle goes into the black hole, annihilates a particle at the core of the black hole, and energy is released, leading to an evaporating black hole. But how do the particles that are the result of annihilation get out of the event horizon if not even photons can escape?
Thanks,
Jake
Nothing gets out of the black hole. The vacuum fluctuation occurs just outside the event horizon. One particle escapes, and the other enters the black hole. The anti-particle negates whatever is in the hole, forming nothing, as in 1+(-1)= zero.
Of course I may be wrong, as it seems to me that particles and anti-particles would have an equal chance of entering the hole, thus negating each other instead of anything in the hole. What am I missing?
It is my understanding that annihilation isn't really annihilation; new particles are formed obeying the conservation of energy. ??
This comes up often; see
George Jones said:
When virtual matter-antimatter pairs are created, the probability that the antimatter particle has positive energy is equal to the probability that the matter particle has positive energy, i.e., both probalilities are 1/2.
Hawking radiation does not come about because antimatter particles sometimes fall into black holes; it comes about because negative-energy particles (both matter and animatter) sometimes fall into black holes. Some popular-level treatments of black holes obscure this, and even sometime get this completely wrong.
Sometimes it is difficult to give accurate non-mathematical descriptions of processes that involve advanced physics. This is particularly true for Hawking radiation - it is very hard to see the correspondence between the non-mathematical description involving virtual matter-animatter pairs and the actual mathematical description.
Steve Carlip is a physicist who tries hard to make physical concepts clear, both for laypersons and for experts. You should read his non-mathematical description of Hawking radiation, which is more challenging than most non-mathematical descriptions, but which also is more accurate than most non-mathematical descriptions. If you have questions about his description, just post them.
What happens, very roughly, is this. Energy is associated with time and spatial momentum is associated with space. When an matter-antimatter pair of virtual particles is created *outside* the event horizon, they can become a little bit separated in the time that the Heisenberg uncertainty principle allows them to live. Tidal forces caused by the curvature of spacetime help them to separate, and, sometimes, the negative-energy particle (which could be either matter or anitimatter) wanders over the event horizon and into the black hole. Inside the event horizon, the roles of time and space coordinates get interchanged. Thus, according to what I wrote above, the roles of energy and spatial momentum get interchanged. What was negative energy becomes a negative spatial component of a local (for an observer inside the horizon) momentum vector. Only a virtual particle can have negative energy, while any particle, real or virtual, can have a negative component of spatial momentum.
Bottom line: the whole process can become a real process. In this real process, an observer outside a black hole "sees" the black hole hole swallow a negative-energy particle while emiitting a positve energy particle (the other member of the matter-antmatter pair). The balck hole radiates.
Regards,
George
So I should have said " negative energy particle" instead of anti-particle. But that doesn't change the basic question - aren't negative and positive energy particles equally likely to fall into the event horizon? Wouldn't they just cancel each other out?
From the link that I gave,
Steve Carlip said:
Note that this doesn't work in the other direction -- you can't have the positive-energy particle cross the horizon and leaves the negative- energy particle stranded outside, since a negative-energy particle can't continue to exist outside the horizon for a time longer than h/E. So the black hole can lose energy to vacuum fluctuations, but it can't gain energy.
  • · Replies 73 ·
  • · Replies 17 ·
