Help with electromagnet design
The discussion revolves around the design and functionality of an electromagnet intended to pull a 5kg weight along a cushion of air, akin to maglev trains. Participants explore various specifications, including wire turns, core material, and voltage requirements, while addressing issues related to current and circuit completion.
  • One participant describes their attempt to create a small electromagnet using 100 turns of 0.2mm copper wire around a 6mm air core, powered by a 9V battery, but reports no force generated.
  • Some participants suggest using an iron core and increasing the current to improve the electromagnet's performance.
  • Another participant questions the circuit completion and suggests that the battery may not be supplying enough current due to the resistance of the wire.
  • Concerns are raised about the suitability of 9V batteries for this application, with suggestions to connect multiple batteries in parallel for increased current.
  • A participant clarifies that the term "cushion of air" was metaphorical, leading to some contention over its interpretation.
  • One participant reports a slight improvement in pull from the electromagnet after adjustments.
Participants express differing views on the effectiveness of the air core versus an iron core, the adequacy of the battery power, and the interpretation of the metaphor used in the initial post. The discussion remains unresolved regarding the optimal design specifications for the electromagnet.
Participants mention limitations related to the fixed length of wire and battery voltage, as well as the current handling capacity of the wire gauge. There are also unresolved questions about the circuit configuration and the actual current being drawn from the battery.
unityunity
Hi everybody,
I just had 100m of copper winding wire arrive in the mail so I can build an electromagnet.
I'm aiming to pull a 5kg weight along, which is already floating on a separate magnetic field so all friction is removed except air resistance.
What I want to do is put an electomagnet in front of this 5kg box, to pull it along on a cushion of air - similar to the Japanese maglev trains.
(except mine is awesome).
So here's the thing.
I'm trying to make the smallest electromagnet I can out of this wire.
I wound it all around a little a plastic air core with a diameter of 6mm. There's 100 turns of wire, wire is 0.2mm, copper, 36SWG.
Hooked up a 9V battery.
Nothing - no force.
I know... you are going to say the number of turns is too low.
But before I spend the next 2 hours going mad winding up this tiny little thing with 100,000 turns, I wonder if someone could help me with a few specs for the design.
Best guess at what size radius core to use (air core), how many turns, and voltage to apply.
I'm stuck with standard battery voltages - multiples of 1.5v, or 9V.
Thanks for your help!
Use an iron core , Up the current .
Thanks for your reply.
I did try with an iron core - no effect.
I'm not sure how to up the current when the resistance is fixed (the length of wire) and the voltage is fixed within those ranges.
You should be able to attract bits of iron with the magnet you have described, air core or iron core. Something is wrong. You did complete the circuit, right? One pole of the battery on one end of the wire, the other pole on the other end? Its possible that you are trying to draw too much current out of the battery, and are dropping its voltage when connected. You really need to be careful in this design. I think SWG36 will only handle about 70 milliamps of current, so you need to make sure that the resistance that your 9v battery sees is about 127 ohms. If the wire does not give you that, then you should drop your voltage until V=IR where I=0.07 amps (70 milliamps) and R is the resistance of your coil.
It isn't on a cusion of air. Air has nothing to do with it.
Sounds like more than enough for a basic magnet.
Put in an iron core and attach as many batteries as possible. If it doesn't attract, I'd say your batteries are cream-crackered.
However, you're not using AA, AAA and 9V (small rectangle) batteries are you? They can't deliver anywhere near enough current. 9V batteries are rated at around 0.2A. Connecting about 10 of them in parallel and you'll get enough to give a good field - although I wouldn't recommend this as it may be dangerous.
It's a metaphor. As in poetry. Thankyou for pointing out the obvious.
Thanks everyone. I got a tiny bit of pull from the electromagnet now.
Well it reads like a statement, and as such is wrong.
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 42 ·
  • · Replies 37 ·
  • · Replies 43 ·
