Black Hole: Conservation of energy
The discussion centers on the conservation of energy in relation to black holes, exploring questions about their mass consumption, evaporation, and the implications of these processes on energy dissipation. Participants examine theoretical aspects, potential limits, and the nature of black holes from both classical and quantum perspectives.
  • Some participants question where the energy goes when black holes consume matter, suggesting possibilities like gamma-ray bursts.
  • Others argue that energy is conserved within the black hole and the surrounding spacetime, with some energy radiated during matter consumption.
  • There is a discussion about whether black holes can have limits on the amount of mass they can consume, with some suggesting that general relativity does not impose such limits.
  • Participants explore the concept of black hole evaporation, noting that larger black holes may gain more mass than they lose, while smaller ones evaporate more quickly.
  • Some contributions suggest that black holes emit Hawking radiation, which is a form of energy loss, while others express uncertainty about the mechanisms of this process.
  • Questions arise about the nature of black hole evaporation and whether it can be induced or if it occurs continuously without the need for fusion processes.
  • There are claims that black holes do not last forever and will eventually evaporate, but the time scales for this process vary significantly based on their mass.
Participants express multiple competing views on the conservation of energy in black holes, the limits of mass consumption, and the nature of evaporation. The discussion remains unresolved, with no consensus reached on several key points.
Some participants highlight the complexity of black hole evaporation and the dependence on various factors, such as mass and temperature, while others note the limitations of current understanding regarding the interplay of energy conservation and black hole behavior.
This discussion may be of interest to those exploring theoretical physics, particularly in the realms of black hole mechanics, quantum gravity, and astrophysics.
darkside00
If black holes exist, they can't consume infinite amount of matter, so where does this energy go if it is not dissipated?
Is it gamma ray bursts that dissipate this huge amount of energy?
Or maybe a better question is, once a black hole is created, how long can it last? or do they last forever?
Astronomy news on Phys.org
I don't exaclty understand where you see conservation of energy being violated. The energy still exists... in the black-hole and the space-time (gravity) around it---its not being 'dissipated' necessarily (although generally a good deal of energy is 'radiated' when material is consumed by a BH).
I don't see how you are relating this to the lifetime of black holes, but what you are alluding to is correct: black-holes do not last forever---they slowly evaporate (but this gets very complicated, and large-black holes will essentially always being gaining more than they're losing). The micro-black holes which could hypothetically be created at the LHC would evaporate in the smallest fraction of a second. And if I recall the numbers correctly, a stellar-mass black hole would take about a Hubble-time (14 billion years) to evaporate.
Can there be a limit of the amount of mass it can pull in (consume)? and
How do supermassive black holes evaporate?
General relativity doesn't have any preferred scales such as a mass scale or a distance scale, so there can't be any such limit.
darkside00 said:
and
The same way less massive ones evaporate...?
You are ascribing black holes 'supernatural' properties. A black hole is entirely well behaved at the Newtonian limit, and equally well up to the GR limit. It only becomes unruly at the event horizon. At that point it behaves reasonably well up to the quantum limit. Inside the event horizon, all bets are off.
can a black hole be destroyed using the same property of evaporation ?
What do you mean by "be destroyed"? Black holes evaporate. That is, they gradually lose mass over time until they disappear if they aren't constantly fed at a rate greater than the evaporation rate.
The rate of evaporation gets smaller (but never zero) as black holes get larger. The rate goes higher as the mass goes down. Really big black holes can 'feed' adequately on just the ambient radiation in the current universe (CMBR). Really small ones can't get enough mass down their gullets to sustain themselves. The 'end game' for black hole evaporation is a rapid flash of energy as the last of the mass within its minuscule event horizon is converted to particles and energy immediately outside of it. Boom!
ok, so once there done feeding, how are they releasing their mass energy?
would it be similar to a dying star? or supernova? there would have to be some fusion to release the energy in the event horizon and eventually become visible...otherwise there is no evaporation rate while its feeding
or become just a big chunk of mass that is stagnant or dead. That would mean it didn't evaporate?
The evaporation is continuous, no matter what. No fusion required. It's just evaporation. If the mass influx is greater than the evaporation rate, the black hole grows. If it's less, it shrinks.
hey buddy its the one and only black hole where physics law's goes wrong or one can simply say the human limits,so there is nothing like conservation of energy in a black hole and there lifetime may very from few nanoseconds (as in case of pie-meson particle interactions) to infinity depending upon amount of matter present around them(IN there intense gravitational field) once they end up eating matter around them they die.
its only for darksidee00 man who put up such a silly question
its when there is nothing left around them in their gr field (as dark energy is pushin things apart slowly but efficiently).
When BH evaporates it is converted into hawking radiation.
Conservations laws hold.
Black Holes has a temperature; any object that has a temperature emits radiation, emitting radiation=loosing mass. Black Hole radiations is also called as Hawking's Radiation.
Space around the black hole is usually colder. Hot flows into colder objects, therefor the space's heat flows into the black hole because black hole has a lower temperature. In addition with the black holes constant absorbing of matter, so therefor the black holes absorb more energy than they loose them.
When space is expanded enough, eventually the temperature around the black hole will become colder than the black hole. Remember hot flows to colder object? So black hole's heat will be carried into space, eventually the black hole will evaporate but this cycle will take a long time as described in the 1st post.
Small black holes= High Temperature=they die(evaporate) faster
Big black holes= Low Temperature=they die(evaporate) slower
I am not entirely sure, so experts please correct this if this is wrong.
(Excuse me for my bad English)
Haven't heard an expert yet
Will have to look more into this hawking radiation
Q;Could this evaporation be induced?forinstance by Excitation.
No. See: http://en.wikipedia.org/wiki/Hawking_radiation
What exactly are you still unsatisfied with? Have you read the above article?
  • · Replies 22 ·
  • · Replies 0 ·
