Thread Closed
Physics Involving Newton's Laws of Motions (specifically g, and the normal force)
Share Thread Thread Tools
Oct5-04, 10:13 PM   #1
An engineer claims to have a new kind of "safety" air-brake for elevators. If the cable should snap, a patented velocity-sensor turns on the brakes once the elevator hits 40 mph. The brakes are powerful enough to stop a 700 lb elevator in 1/20 of a second.
How much force do the brakes exert to stop the elevator like this? Why isn't the answer 700 lbs? Isn't the force of gravity only 700 lbs?
I'm not sure where to begin with this one, I understand the concept of the elevator is being held taut by the elevator cord, and that on the sides, there is Ff (f=friction), but I am not really sure what to do with the information being given to me in this problem. Could someone give me a general idea how I should attempt this problem? Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct5-04, 10:23 PM   #2
Recognitions:
Homework Helper Homework Help
The elevator will be moving downwards, and it will have a weight of 700 lbs, so the problem states when the elevator has a speed of 40 mph, then it can stop it, reach a speed of 0 in 1/20 of a second. (Acceleration Equation is ?)
The answer is not 700 lbs, because the elevator is moving.
Do a freebody diagram, the brake is supposedly air-brake, so i doubt there will be friction on the sides.
Oct5-04, 10:42 PM   #3
ok, I somewhat understand the problem a little better, but I did something wrong...
a=g=9.8 since acceleration is constant? because the cable just snaps, so it's just gravity, and a can be set equal to
a=Force/mass
and mass is equal to weight/g which in this case, then 700 lbs/9.8 m/s^2 gives me 71.4285714286, so then, I times both sides by mass, and get
(9.8)(71.4285714286) = 700 N, so but that was already ruled out, what did I mess up?
I have another equation where F=(micro)N where (micro)=coefficient of friction and N=normal, but I don't have to coefficient of friction in this problem, so I can't really use that
Oct5-04, 10:45 PM   #4
Recognitions:
Think about the brake.
You got the Force the brake will exert to stop the elevator from falling and you got the weight of the elevator, on your diagram, and their moving on the y-axis.
Oct6-04, 07:36 AM   #5
not really, I'm still lost on this problem... gah, so much work for just one problem... UGH.
Oct6-04, 03:16 PM   #6
Recognitions:
Think about
[tex] \sum_{i=1}^{n} \vec{F}_{i} = \frac{d \vec{P}}{dt} [/tex]
[tex] \sum_{i=1}^{n} \vec{F}_{i} = \frac{\Delta \vec{P}}{\Delta t} [/tex]
[tex] \sum_{i=1}^{n} \vec{F}_{i} = \frac{m \Delta \vec{v}}{\Delta t} [/tex]
By the way that's newton second law, and P is lineal momentum.
If the mass is constant, then it'll be:
[tex] \sum_{i=1}^{n} \vec{F}_{i} = \frac{m d \vec{v}}{dt} [/tex]
[tex] \sum_{i=1}^{n} \vec{F}_{i} = m \vec{a} [/tex]
Thread Closed
Thread Tools
Similar Threads for: Physics Involving Newton's Laws of Motions (specifically g, and the normal force)
Thread Forum Replies
Force and Newton's Laws Introductory Physics Homework 14
HELP! problem involving force of friction and normal force Introductory Physics Homework 7
Please Help...involving force and newtons laws Introductory Physics Homework 3
Free body diagram involving normal force, gravitational force, and applied force. Introductory Physics Homework 4
Force and Newton's Laws Introductory Physics Homework 2
