Mathematica - Problem with axes
  • Context: Mathematica
  • Thread starter Thread starter LouisPhilippe
    Axes Mathematica
The discussion revolves around a problem encountered by a user in Mathematica regarding the manipulation of plots of differential equations. The user seeks to maintain fixed axes during parameter adjustments to facilitate graph comparison.
  • Technical explanation, Homework-related
  • The original poster expresses difficulty in keeping the axes fixed while using sliders to manipulate parameters in Mathematica plots.
  • One participant suggests using the PlotRange option to define the axis limits explicitly.
  • Another participant points out the AxesOrigin option as a potential solution for fixing the axes at the origin.
  • The original poster confirms that combining both suggestions resolved the issue.
None noted.
Users of Mathematica who are working with manipulable plots and require fixed axes for better comparison of graphs.
LouisPhilippe
Hi,
I have just started working with mathematica and I am making a few manipulable plots of differential equations. The problem is that when I use the slider to change the value of certain parameters, the size of both axes change along, which makes it difficult to compare graphs.
I would like to have my axes "fixed", meaning they cut each other in coordinate (0,0) and preferably also with a fixed scaling (for example x-axis range from 0 to 10 and y-axis range from 0 to 5)
I don't think this should be too hard but I've spent quite some time looking for this in the help documents, but I just can't seem to find it!
Help would be greatly appreciated!
Louis-Philippe
Try adding a PlotRange option to your Plot
Plot[x^3, {x, 0, 2}, PlotRange -> {{0, 10}, {0, 5}}]
and see if this fixes your problem
Also the option http://reference.wolfram.com/mathematica/ref/AxesOrigin.html" .
The combination of the two fixed my problem perfectly,
Thanks for your help!
Louis-Philippe
  • · Replies 0 ·
  • · Replies 18 ·
