Cauchy riemann equations and constant functions
The discussion revolves around the properties of analytic functions, specifically regarding the Cauchy-Riemann equations and the implications of a constant modulus for the function f(z). The original poster questions whether a function that is analytic and has a constant modulus must also be constant.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between the modulus of an analytic function and its constancy, referencing the Cauchy-Riemann equations. Some participants provide reasoning based on analytic properties and counterexamples, while others question the assumptions regarding the domain of the function.
The discussion includes attempts to prove that if the modulus of f(z) is constant, then f must also be constant. Some participants have raised counterexamples and clarified assumptions about the domain, leading to a more nuanced exploration of the problem without reaching a definitive conclusion.
There is a noted confusion regarding the domain H, with participants discussing the implications of the unit disk versus the unit circle and the need for open and connected domains in the context of the problem.
reb659
Let f(z) be analytic on the set H. Let the modulus of f(z) be constant. Does f need be constant also? Explain.
Hint: Prove If f and f* are both analytic on D, then f is constant.
I think f need be constant.
Let f*=conjugate operator
Let f = U+iV Then f* = U-iV
Since F is analytic we can use CR equations and we get
1) Ux = Vy
and
2) Uy = -Vx .
Applying CR to f* gives
3) Ux = -Vy
and
4) Uy = Vx
1) and 3) imply Vy = -Vy and 2) and 4) imply Vx = -Vx.
But the only function that can equal its negative is zero, and thus Vx = Vy = 0, and so V = constant.
Likewise, the same argument for Ux and Uy gives Ux = Uy = 0 and so U = a constant. And both U and V constant implies that f is constant. So we have the hint proven. Let f = u+iv. We’re given |f| = c.
Stuck.
Hint: f times f* is |f|^2 which is a constant.
But what about the function f(z)=z=x+iy? Isn't that function analytic on the say, unit disk with a constant modulus but f is not constant?
If you mean the unit disk, it doesn't have constant modulus. If you mean the unit circle, yes, it does. They should have stated assumptions on the domain H. Let's say it needs to be open and connected.
Ah yes, I meant unit circle. I was thinking the domain would need to have restrictions because I thought I proved it yet found a counterexample at the same time. But for the original problem:
Let f=U + iV. We have |f|=c for some constant c. |z|^2=zz*, so we have |f|^2=c^2 which implies f*=c^2/f. f is analytic by assumption and constants are always analytic over any D, so by the above hint I proved f must be constant.
Sure, that's it.
  • · Replies 27 ·
  • · Replies 19 ·
