Distance of point to line (cross product)
The discussion revolves around finding the distance from a point to a line in three-dimensional space using the cross product. The original poster presents a specific example involving points A, B, and C, and attempts to apply the cross product formula to derive the distance.
  • The original poster attempts to use the cross product to find the distance but encounters confusion regarding the calculation of the magnitude of the cross product and its implications. Some participants suggest alternative methods, such as vector projection, while others seek clarification on the use of trigonometric relationships in the context of the cross product.
Participants are actively engaging with the problem, exploring different methods and questioning the original poster's understanding of the cross product. Some guidance has been offered regarding the determinant method for calculating the cross product, but there is still uncertainty about the application of these concepts to find the distance.
There is a noted confusion about the relationship between the cross product and the sine of the angle between vectors, as well as how to compute the necessary magnitudes. The discussion reflects a mix of attempts to clarify these concepts and explore alternative approaches to the problem.
quietrain
hi
i was wondering how exactly one should find the distance of a point to a line using cross product
for example, the distance from A(1,2,0) to a line running through B(0,1,2) & C(3,1,1) with Y being angle between BA and BC
BC = 3,0,-1
BA = 1,1,-2
so by using cross product formula, i get |BA|sin(Y) = |BAxBC| / |BC|
i tried to calculate |BAxBC| by using the determinant method and i got 0, so the length = 0 too. how come?
so how do i compute the value |BAxBC| ? if i equate to |BA||BC|sinY, wouldn't it cancel out everything in the equation?
so i tried just calculating |BA|sinY by squaring & subsituting sin2Y to (1-cos2Y) and then using the dot product rule and then squarerooting it to get the answer sqrt3.5
so what have i done wrong? is my concept wrong? which way is correct? thanks!
quietrain said:
hi
BC = 3,0,-1
BA = 1,1,-2
The easiest way I can think of off the top of my head is to project the vector on to the line and then subtract the projected vector from the point vector.
So to recap:
1) Project "point-vector" on to the "line-vector"
2) Subtract result of 1) from "point-vector"
3) Calculate the distance of vector in 2 to get your distance
So to recap:
ah thank you for telling me another alternative
but i still don't understand how to use the cross product to calculate the distance, because my notes says one can use cross product to do so.
Think back to trigonometry. When you have the sin of the angle and the length of a side, what can you deduce about finding the other respective side?
Also remember that one side will be perpendicular since that is the shortest vector between the point and the line.
i know that sin theta will give you the opposite perpendicular side, but if you see the formula that i have written on my 1st post, the formula in essence is self cancelling.
which puzzles me on how exactly should i compute |BA|sin(Y) = |BAxBC| / |BC|
"so how do i compute the value |BAxBC| ? if i equate to |BA||BC|sinY, wouldn't it cancel out everything in the equation?"
What you are doing is correct:
The definition of A x B (A and B are vectors) is
A x B = |A||B|sin(theta)N where N is the normal vector.
Based on this we can calculate |A X B| as
|A x B| = |A||B|sin(theta)|N| = |A||B|sin(theta) x 1 = |A||B|sin(theta)
Dividing by |A| you get
|A X B|/|A| = |B|sin(theta)
which is what you want.
oh so i just use the determinant formula to get |A X B| and then find the magnitude and then divide by the magnitude of |A|?
To find A x B you use the determinant
| i j k |
| Ax Ay Az|
| Bx By Bz|
where the x,y,z are the components of the respective axis and (i,j,k) are the standard basis in euclidean 3 space.
To Find |A X B| use the norm which is basically
d = SQRT(x^2 + y^2 + z^2) where (x,y,z) = A x B
Finding |A| is the same.
| i j k |
| Ax Ay Az|
| Bx By Bz|
ah i see thanks!
