Cooling a Room with 8.4*10^6J/h: How Long?
  • Thread starter Thread starter Kelju Ivan
    Cooling
The discussion focuses on calculating the time required to cool a room with a volume of 62.5m³ from 30°C to 25°C using an air conditioner with a cooling power of 8.4*10^6 J/h. The participants analyze the behavior of diatomic gas under constant pressure and volume conditions, applying the ideal gas law and heat capacity equations. Key equations derived include the relationship between power, heat capacity, and temperature change, specifically using the formula PΔt = (5p₀V₀/2kₐ) ln(T_final/T_initial). The discussion highlights the distinction between using C_V and C_P for diatomic gases, emphasizing the importance of context in selecting the appropriate heat capacity.
  • Understanding of the ideal gas law and its application
  • Familiarity with diatomic gas properties and heat capacities
  • Knowledge of thermodynamic principles, particularly heat transfer
  • Ability to perform logarithmic calculations in thermodynamic contexts
  • Research the differences between C_V and C_P for various gas types
  • Learn about the ideal gas law and its applications in thermodynamics
  • Explore the concept of heat transfer in constant pressure systems
  • Study the implications of Boltzmann's constant in thermodynamic equations
Students and professionals in physics, engineering, and HVAC design, particularly those interested in thermodynamics and heat transfer calculations.
Kelju Ivan
Air conditioner cools the air in a room with a power of 8.4*10^6J/h. Volume of the room is 62.5m^3. At first the air is at the temperature of 30C and air pressure is 1atm, which stays a constant. How long does it take to cool the room to 25C? Note that the air shrinks while cooling down and since the pressure stays constant, more air (at 30C) flows in from the outside. Treat the air as a diatomic gas.
I am overwhelmed by this exercise. Normally I could make the equation (S is the integral sign) S Pdt = S nRdT (n=pV/RT), but now more air is flowing in, all the time warming the room and making the n change. How the hell does this work?
Ok, so you know that both the temperature and number of particles change with time. The pressure and volume are both constants. So, we can right
[tex]p_{0}V_{0} = N(t)k_{b}T(t) \Rightarrow N(t) = \frac{p_{0}V_{0}}{k_{b}T(t)}[/tex]
Next, we can right the power as
[tex]P = \frac{dQ}{dt} = C_{V}\frac{dT}{dt}[/tex]
It says that you have a diatomic gas. We know that the heat capacity of a diatomic gas is
[tex]C_{V} = \frac{5}{2}Nk_{b}[/tex]
Substituting for the heat capacity and the number of particles,
[tex]P = \frac{5p_{0}V_{0}}{2k_{b}T(t)}\frac{dT}{dt}[/tex]
Thus,
[tex]P\Delta t = \frac{5p_{0}V_{0}}{2k_{b}} ln \frac{T_{final}}{T_{initial}}[/tex]
That differs a bit from the answer we were shown, but I guess it does just the same thing, you just used Boltzmann's constant instead of R.
In our version we had [tex]C_p=\frac{7}{2}R[/tex]. I'm not really sure when I should use 5/2 and when 7/2, since both are valid for [tex]C_p[/tex].
[tex]t=Q/P[/tex] where
[tex]Q=nC_p\Delta T[/tex] and [tex]n=\frac{pV}{RT}[/tex]
10K
15K
  • · Replies 82 ·
29K
32K
