New Reply
Grade 9 Power Problems (Watts/kWh, power rating question)
Share Thread Thread Tools
Jan16-11, 07:08 PM   #1
So, i need to learn how to do questions with finding out the power rating, and energy etc etc from using the triangles given and i am having some trouble since some of my triangles are missing and i need some help with converting.
2. Relevant equations
1) A hot plate has a power rating of 1250 Watts. How much energy in Kilowatt-hours is used when this hot plate is used for 3.00 hours at a banquet?
3. The attempt at a solution
I converted the watts to kWh so i turned 1250 to 1.25. On the triangle with the variables of "P," "E," and "T," it says E=Pt So i did 1.25*3 and got 3.75kWh.
The problem is that i thought that "E" was always in joules or Kilojoules so i do not think the answer can be 3.75kWh since that is the power rating.
If i am correct, i need help with converting the 3.75kWh into joules if that is what i need to do.
Thanks !!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jan16-11, 09:43 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
1 Watt = 1 Joule/second
1 Watt*hour = (1 Joule/second)*3600 seconds = 3600 Joules
1 kWh = 1000 Watt*hour
Got it?
New Reply
Thread Tools
Similar Threads for: Grade 9 Power Problems (Watts/kWh, power rating question)
Thread Forum Replies
Question(Physics 20) about Power(watts) Introductory Physics Homework 5
calculate power rating per channel in watts (rms) Introductory Physics Homework 0
resistor power rating General Engineering 1
Power supply -- Importance of amp Rating?? Electrical Engineering 3
Watts and Power Electrical Engineering 3
