Is There Any Reversible Quasi-Static Process?
  • Context: Graduate
  • Thread starter Thread starter Kevin_Axion
    Process Quasi-static
A quasi-static process is typically reversible, as it maintains thermal equilibrium between the system and its surroundings throughout the process. However, a quasi-static process that takes an infinitely long time without maintaining this equilibrium is not reversible. An example of a reversible quasi-static process is heat transfer from an infinitely large reservoir to a gas, allowing it to expand against an external pressure. In contrast, a gas escaping into a vacuum through an infinitesimally small hole represents a quasi-static but irreversible process.
  • Understanding of thermodynamic principles, specifically reversible and irreversible processes.
  • Familiarity with the concept of thermal equilibrium.
  • Knowledge of quasi-static processes and their characteristics.
  • Basic grasp of gas laws and behavior under varying pressures.
  • Research the laws of thermodynamics, focusing on reversible and irreversible processes.
  • Explore the concept of thermal equilibrium in detail.
  • Study examples of quasi-static processes in thermodynamic systems.
  • Learn about the implications of gas behavior in different pressure scenarios.
Students and professionals in physics, engineering, and thermodynamics, particularly those interested in the principles of energy transfer and system behavior in thermodynamic processes.
Kevin_Axion
Just out of curiosity, is there any quasi-static process that is completely reversible? I think the answer is an obvious no because any quasi-static process experiences a net energy loss but I'd like to know if there are any, possibly something abstract rather then mechanical.
Science news on Phys.org
Quasi-static processes ARE usually reversible. A reversible change is one in which the system and its surroundings are arbitrarily close to being in thermal equilibrium at all times. A quasi-static change is one that takes an arbitrarily long time to complete. Both are ideal situations and are not really achievable in practice.
AM
Just as a follow-up. A quasi-static process that is not reversible would be one which takes an infinitely long time to complete but during which the system and surroundings are not infinitessimally close to equilibrium.
An example of a reversible process would be heat flow from an infinitely large reservoir at temperature T + dT to a system gas at temperature T. Heat would flow from the reservoir to the gas reversibly (ie system and surroundings are arbitrarily close to equilibrium at all times) and the gas at pressure P + dP would expand and do work at an infinitessimally slow pace (ie. quasi-static) against an external pressure P.
Now if, instead of doing work on its surroundings by expanding arbitrarily slowly against an external pressure of P, the gas simply escaped at an arbitrarily slow rate into a vacuum through a hole in the system container that was infinitessimally small, the process would be quasi-static (ie it would take an infinite or arbitrarily long time) but would not be reversible (you could not with an arbitrarily small change in conditions get the gas to flow back from the vacuum into the system container).
AM
  • · Replies 21 ·
  • · Replies 19 ·
