Understanding EMF, Potential Difference & Current Flow
  • Context: High School
  • Thread starter Thread starter rahuld.exe
    Emf
The discussion clarifies the distinction between electromotive force (EMF) and potential difference in electrical circuits. EMF represents the maximum potential difference when no current flows, while potential difference occurs when current is actively flowing through the circuit. The internal resistance of a battery affects the actual potential difference available when connected to a closed circuit, as it impedes the flow of ions necessary for current generation. Understanding these concepts is crucial for analyzing battery performance and circuit behavior.
  • Basic understanding of electrical circuits
  • Knowledge of battery chemistry and internal resistance
  • Familiarity with the concepts of current flow and voltage
  • Understanding of closed vs. open circuits
  • Research the impact of internal resistance on battery performance
  • Learn about the chemical reactions in batteries that generate EMF
  • Study Ohm's Law and its application in circuit analysis
  • Explore the differences between AC and DC circuits
Electronics students, electrical engineers, and anyone interested in understanding the principles of electromotive force and potential difference in circuits.
rahuld.exe
'it is emf when no current is flowing outside the cell. Whereas, it is potential difference is when current actually flows out of the cell."
"that emf is the potential difference when there is no current flowing through the circuit or when the key is open. Whereas, the circuit has certain value of potential difference when there is current flowing through the circuit."
i read it somewhere n i guess both mean the same... can someone please explain what, how, when, why (basically, everything about it)... in case they don't mean the same thing kindly explain both...
regards
The electromotive force is the theoretical maximum value for the potential difference the battery can maintain, based on how it was built.
When you connect the battery to a closed circuit, inside the battery is triggered a chemical reaction that sustain this potential difference. There are ions inside the battery that must move constantly, providing the electrons to go around the circuit. The problem is, this movement of the ions is not instantaneous and electrons are not readily available. This time for the electrons to become available acts somewhat like an internal resistance of the battery. Since the current of ions inside the battery have this internal resistance they must overcome, it reduces the actual potential difference that the battery can maintain when it is connected to a circuit.
hmm.. that helped.. thanks!
  • · Replies 16 ·
  • · Replies 17 ·
