Graph inequality in complex plane; negative z value
The discussion focuses on graphing the inequality |1 - z| < 1 in the complex plane. The transformation of the inequality to the form |z - 1| < 1 is confirmed as correct, demonstrating that the distance from z to 1 is less than 1. This indicates that the solution represents a disk centered at 1 with a radius of 1 in the complex plane. Participants validate the procedure, affirming the mathematical principles involved.
  • Understanding of complex numbers and the complex plane
  • Familiarity with absolute value properties in complex analysis
  • Knowledge of graphing inequalities in two dimensions
  • Basic concepts of distance in metric spaces
  • Explore the properties of complex number inequalities
  • Learn about graphing regions in the complex plane
  • Study the implications of transformations in complex analysis
  • Investigate the geometric interpretations of complex functions
Mathematics students, educators, and anyone interested in complex analysis and graphing techniques in the complex plane.
merzperson
Graph the following inequality in the complex plane: |1 - z| < 1
2. The attempt at a solution
In order to graph the inequality I need to get the left side in the form |z - ...|
|1 - z| < 1
|(-1)z + 1| < 1
|-1(z - 1)| < 1
|-1||z - 1| < 1
(1)|z - 1| < 1
|z - 1| < 1
From here I know how to graph it, but I'm not sure if my procedure is correct. Does this look right?
Sure it's correct. |a-b|=|b-a|. The proof is just what you showed. And they are both the distance from a to b.
Thanks, didn't notice that.
