Find Equilibrium with Electron Field on Figure 22-11
  • Thread starter Thread starter rishid
    Electron Field
The discussion revolves around determining equilibrium points for an electron in the presence of fixed charged particles, as illustrated in Figure 22-11. Participants are exploring the conditions under which an electron can achieve equilibrium on the left side of these charges.
  • Participants are discussing a non-computational technique to analyze the net forces acting on an electron at various points along the axis. There are inquiries about the direction of forces and the application of Coulomb's Law to find equilibrium points. Some participants express confusion about the calculations and the implications of charge signs on force direction.
The discussion is ongoing, with some participants providing insights into the conceptual framework for determining equilibrium points. However, there is a lack of consensus on the specific calculations and interpretations of force directions, indicating that further exploration is needed.
Participants are grappling with the implications of unknown distances in their calculations and the effects of different charge magnitudes and signs on the forces experienced by the electron.
rishid
Figure 22-11 shows four situations in which charged particles are fixed in place on an axis.
http://www.webassign.net/hrw/22_11.gif
Figure 22-11.
In which situations is there a point to the left of the particles where an electron will be in equilibrium?
Need some help, have absolutely no idea where to start.
Can be more then one answer I suppose.
thanks for any help,
RishiD
Here is a non-computational technique.
Divide the line into three regions.
Choose a point in the far-left in the left region.
What is the direction of the net force on an electron placed at that point?
Intuitively, from far away, two charges in the middle are practically on top of each other. That is, we can think of them as a single point charge of size q1+q2.
Now choose a point just to the left of the left charge.
Intuitively, being so close to the left charge, the force on the electron is dominated by that left charge.
If the direction of the net force at the near-left point has changed from that of the far-left point, then there must have been a point where the net force was zero... somewhere between the far-left point and the near-left point.
If you want to locate that point exactly, you'll have to do some algebra.
(You can generalize this idea to locate equilibrium points, if any, in the center region and in the right region.)
What equation is that to find that?
Coulomb's Law, applied once for each charge applying a force on the electron.
Sorry I just cannot seem to any get any valid answers out of this...
F=(k*Q1*Q2)/r^2
r is unknown, so for example A
Q1 = +1 Q2 = -3
So wouldn't the force always be negative?
Think this way:
the electron is repelled by the negative charge, and
the electron is attracted by the positive charge.
At the point in question, which force is stronger?
