Integral over a Rotated Ellipse
  • Thread starter Thread starter SpringPhysics
    Ellipse Integral
The integral of the function f(x,y) = xy over the ellipse defined by the equation x² - xy + 2y² = 1 can be transformed into an integral over the unit circle using a rotation change of variables. The angle of rotation, necessary to eliminate the cross term, can be calculated using the formulas x = x' cos(θ) - y' sin(θ) and y = x' sin(θ) + y' cos(θ). The correct angle of rotation is determined to be -π/8, contrasting with the expected π/8 from standard formulas. This transformation allows for the application of polar coordinates to simplify the integration process.
  • Understanding of conic sections and their equations
  • Familiarity with polar coordinates and their applications in integration
  • Knowledge of rotation transformations in two-dimensional space
  • Ability to solve systems of equations involving trigonometric functions
  • Study the derivation of rotation formulas for conic sections
  • Learn about the application of polar coordinates in double integrals
  • Explore the concept of shear transformations in coordinate geometry
  • Investigate the properties of integrals over transformed regions
Mathematics students, particularly those studying calculus and multivariable integration, as well as educators looking for examples of transforming integrals over complex regions.
SpringPhysics
Determine the integral of f(x,y)=xy over x^2 - xy + 2y^2 = 1 in terms of an integral over the unit circle.
The associated hint is to complete the square (which I did...and got messy expressions for x and y). I would like to know how to start the problem, since changing directly to polar coordinates will not work. I have tried to use the rotation change of variables (after which I can use polar coordinates), but I do not know the angle of rotation nor the lengths of the semi- axes.
Is there another change of variables that I am overlooking?
Thanks.
This page tells you how to find the angle of rotation to get rid of the cross term.
http://www.sparknotes.com/math/precalc/conicsections/section5.rhtml
Or you could derive it yourself by using the rotation formulas
[tex]\begin{align*}<br /> x &= x' \cos \theta - y' \sin \theta \\<br /> y &= x' \sin \theta + y' \cos\theta<br /> \end{align*}[/tex]
Substitute in for x and y and solve for the angle that causes the cross term to vanish.
I solved the tedious resulting system of equations and got 3=2...which means that there is no such rotation?
EDIT: I get the angle of rotation as 0 when solving for the coefficient of xy to be 0, but according to the formula from the link, the angle should be pi/8.
EDIT2: I get -pi/8 for the angle of rotation, as opposed to the pi/8 by using (A-C)/B.
I did some research and found the change of coordinates related to the shear factor. I believe this makes more sense because the x-intercepts of the ellipse corresponds to the x-intercepts of the unit circle. So now it's a question of how to determine where the vector (0,1) is mapped to on the ellipse.
On second thought, I'll just stick with the rotation and scaling.
Thanks for your help.
