Confusion spinning falling objects vs spinning objects
The discussion centers on the differences between spinning objects on Earth and in orbit, specifically regarding weight and energy required to spin them. It is established that while an object weighs 11% less in orbit due to reduced gravitational force, its mass remains constant. The energy needed to spin an object is determined by its moment of inertia, which is dependent on its mass, not its weight. Therefore, the energy required to achieve the same RPM for an object in orbit is the same as for an object on Earth, regardless of the gravitational influence.
  • Understanding of gravitational force and weightlessness
  • Knowledge of moment of inertia and its relation to mass
  • Familiarity with concepts of energy and rotational dynamics
  • Basic principles of physics regarding forces and motion
  • Research the concept of moment of inertia and its calculations
  • Explore the differences between gravitational mass and inertial mass
  • Learn about the physics of weightlessness in orbital mechanics
  • Investigate energy requirements for rotational motion in different gravitational fields
Physics students, aerospace engineers, and anyone interested in understanding the dynamics of spinning objects in varying gravitational conditions.
D9 XTC
OK, so this is what I read:
<< Moderator added link for attrubution >>
http://education.jlab.org/qa/gravity_01.html
In space we feel weightlessness because the Earth's gravity has less effect on us. Why do we not see the effect of the gravitational force between the various objects in a spacecraft ? We see them floating around. Since the objects in a spacecraft are comparatively close to each other we should be able to see the gravitational effect between them.
Although the Earth's gravity has a lesser effect on an astronaut orbiting the Earth in a spaceship than on a person on the surface of the Earth, this is not the reason why an astronaut experiences weightlessness. The space shuttle, International Space Station and most other manned vehicles don't get that far from the Earth. The Earth's gravitational attraction at those altitudes is only about 11% less than it is at the Earth's surface. If you had a ladder that could reach as high as the shuttle's orbit, your weight would be 11% less at the top. Put another way, a person who weighs 100 pounds on the Earth's surface would weigh about 89 pounds at the top of the ladder.
The reason why the person wouldn't feel weightless is because they are being pushed by the ladder - it is keeping them from falling. If they were to jump off the ladder, then they would feel weightless, at least up until the time they splatted on the ground. This is why astronauts feel weightless. The astronaut, the spaceship and everything inside it are falling towards the Earth. The reason why the astronaut doesn't go splat is because the Earth is curved and the astronaut, the spaceship and everything inside it are moving 'sideways' fast enough that, as they fall towards the Earth, the surface of the Earth curves away from them. They are always falling towards the Earth, but they never get there.
The reason why you don't see gravitational effects between objects in a spacecraft is because gravity is a very, very weak force. Of the four basic forces that scientists are sure about, gravity is, by far, the weakest one. Have you ever tripped and fallen down? Well, it took the whole planet to do that to you. Have you ever seen a sock stick to a shirt after it has come out of a dryer? That static cling, created by a slight imbalance of charge between the sock and the shirt, is stronger than the gravitational attraction of the Earth. The gravitational attraction between two small objects in a spacecraft would be overwhelmed by other forces, such as the force of the air being circulated throughout the spacecraft . Although the force of attraction is there, it is so weak that special care would have to be taken to notice it.
Here's what I'm confused about. Let's say there is an object that weighs a ton on Earth's surface and a replica of that object in orbit at the distance where it weighs 11% less. Let's say I want to get them both spinning at the same RPM just because. I'm guessing the object in orbit takes less energy to get spinning at the same RPM as the object on Earth but how much less? Will the fact the the object in orbit is "falling" cause it spin more easily than just 11% easier? Or is the amount of force to spin the object defined by its weight? I'm not really sure where to start but I want to find out the answer to this pretty bad.
And if someone knows all these answers... how much energy would it take to spin a third replica of the object on Earth, to the same RPM as the other two objects, so far from any gravitational pull that it is truly weightless?
The object in orbit will take the same amount of energy to spin at the same rpm.
What you are mixing is mass and weight. The weight is what a scale would show as the result of a measurement. In the thought experiment on orbit the scale would show 11% less than on the surface of the earth. But the inherent (gravitational) mass the object has stays the same. Now the energy need to send the object spinning depends on moment of inertia, which itself depends on (ineratial) mass. To current date no difference between ineratial and gravitational mass has been measured.
So to send the object spinning you will need the same amount of energy, no matter where the object is in the gravitational field. (Of course this only holds for reasonably sized obejcts)
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 22 ·
