Differentiation of power series
The problem involves demonstrating that a specific series converges to 4 by differentiating the function \(x^{2}e^{-x}\). The context is within the study of power series and their manipulations.
  • Participants discuss the differentiation of the power series for \(e^{-x}\) and its multiplication by \(x^{2}\). There are questions about the correctness of the series representation and the implications of plugging in specific values.
Participants are actively engaging in clarifying the steps taken in the original poster's approach. Some have pointed out potential mistakes in the setup and interpretation of the series, while others suggest alternative ways to express the series to avoid errors.
There is a noted discrepancy regarding the starting index of the summation and concerns about the accuracy of the left-hand side of the equation when substituting values. Participants are also reflecting on their preferred methods for handling power series.
simmonj7
Show that 4 = [tex]\sum[/tex] from n = 1 to [tex]\infty[/tex] (-2)[tex]^{n+1}[/tex] (n+2)/n! by considering d/dx(x[tex]^{2}[/tex]e[tex]^{-x}[/tex]).
Power series for e[tex]^{x}[/tex] = [tex]\sum[/tex] x[tex]^{n}[/tex]/n! from 0 to [tex]\infty[/tex].
So I started with the power series for e[tex]^{-x}[/tex] = [tex]\sum[/tex] -x[tex]^{n}[/tex]/n! from 0 to [tex]\infty[/tex] = 1 - x + x[tex]^{2}[/tex]/2! - x[tex]^{3}[/tex]/3! +...
I multiplied both sides of the equation by x[tex]^{2}[/tex] so I got x[tex]^{2}[/tex]e[tex]^{-x}[/tex] = x[tex]^{2}[/tex] - x[tex]^{3}[/tex] + x[tex]^{4}[/tex]/2 - x[tex]^{5}[/tex]/6 +...
Now I took the derivative of both sides: 2xe[tex]^{-x}[/tex] - x[tex]^{2}[/tex]e[tex]^{-x}[/tex] = 2x - 3x[tex]^{2}[/tex] + 4[tex]^{3}[/tex]/2 - 5x[tex]^{4}[/tex]/6 +...
Now I figured that if I just plugged in x= -2, I would get (-2)(-2)e[tex]^{2}[/tex] - (-2)[tex]^{2}[/tex]e[tex]^{2}[/tex] = 2(-2) -3(-2)[tex]^{2}[/tex] + 4(-2)[tex]^{3}[/tex]/2 -...
Now the right hand side would equal the sumation which was stated in the problem i.e. [tex]\sum[/tex] (-2)[tex]^{n+1}[/tex] (n+2)/n! however the summation I get starts at n = 0 rather than n = 1.
Also, as you can clearly see, the left hand side of my equation does not equal 4 like it is supposed to.
If anyone could tell me where I went wrong that would be greatly appreciated. Thanks!
Is there a pair of parentheses missing or do you really mean
[tex](-2)^{n+1}n+2/n![/tex]
as opposed to
[tex](-2)^{n+1}(n+2)/n![/tex]
I mean (-2)^n+1 (n+2)/n!
Your mistake is in your first step:
[tex]e^{-x} \neq\sum_{n=0}^{\infty}\frac{x^{n}}{n!}[/tex]
That's another typo. I know e^-x equals the sum of (-x)^n/n! so that is not my mistake. If you looked at the work I did you would see that I used that sumation to get my answer rather than the one in the typo.
I see. Then the mistake happens when you plug in -2 and say that it's the sum you were looking for. The alternating - signs in your expression cancel the - signs in the (-2)^(n+1).
By the way, I think it's a lot easier in this case and most cases to deal with the expressions kept in terms of 'n' instead of using a "...".
e.g., writing the derivative as
[tex]-\sum_{n=0}^{n=\infty}(n+2)\frac{{(-x)}^{n+1}}{n!}[/tex]
instead of
2x - 3x + 4/2 - 5x/6 +...
I think you will tend to make fewer mistakes this way and they will be easier to correct.
Ok...I see what you're saying but I'm not quite sure what you are trying to say here as far as where I was supposed to go instead. And your explanation still doesn't cover what went wrong with the left hand side either and that it does not equal 4...
I have been taught to do it the way I am doing it so I am going to stick with what I've been taught for power series.
I think you're on the right track. Notice that the left hand side of your equation is zero. Also, you mention that your series goes from 0 to infinity rather than 1 to infinity. Look at the value of the first term in that series. What would your equation be if you moved that value to the other side?
Ok, but do you see what number you can stick into
to get the sum you want to appear?
Ah! That's perfect kanato! Thanks!
Except the left hand side isn't 0 when you plug in -2. That was another mistake on your part. But it's the right method once you do plug in the right number.
