Complex Analysis - Proving a bijection on a closed disk
The problem involves proving that a specific function, defined on the complex plane excluding a certain point, is a bijection on the closed disk for a given condition regarding the parameter w. The context is within the subject area of complex analysis, particularly focusing on mappings and properties of functions in the complex plane.
  • Participants discuss how to compute the inverse of the function and the implications of the hint regarding the mapping of the unit circle. There is confusion about the meaning of "into itself" and how to demonstrate that the function and its inverse maintain the property of mapping the circle to itself.
Some participants are attempting to clarify the steps needed to show the required properties of the function and its inverse. There is a focus on understanding the relationship between the modulus of the function and the unit circle, with guidance being offered on how to approach the proof.
Participants express uncertainty regarding the initial steps of the proof, particularly in relation to the hint provided and the implications of the conditions set by the problem.
semithinking
For each [tex]w \in \mathbb{C}[/tex] define the function [tex]\phi_w[/tex] on the open set [tex]\mathbb{C}\backslash \{\bar{w}^{-1}\}[/tex] by [tex]\phi_w (z) = \frac{w - z}{1 - \bar{w}z}[/tex], for [tex]z \in \mathbb{C}\backslash \{\bar{w}^{-1}\} \back[/tex].
Prove that [tex]\phi_w : \bar{D} \mapsto \bar{D}[/tex] is a bijection on the closed disk [tex]\bar{D}[/tex] for [tex]w \notin \bar{D}[/tex].
Hint: Compute the inverse of [tex]\phi_w[/tex] and prove first that both [tex]\phi_w[/tex] and [tex](\phi_w)^{-1}[/tex] map the circle [tex]\mathbb{T}[/tex] into itself.
So following from the hint, I can calculate the inverse of [tex]\phi_w[/tex]. But I before I can start, I'm getting lost even at how I would show mapping the function and it's inverse to a circle...(I'm even more confused by "into itself".)
You want to show that if |z|=1 then |phi_w(z)|=1. Use that |z|=1 is equivalent to zz*=1.
So I would substitute zz* into |phi_w(z)| to see if it's 1?
No. You want to show (phi_w(z))(phi_w(z))*=1 for any z such that zz*=1.
