Relativity and the mass of photons.
The discussion revolves around the mass of photons and their energy-mass relationship, exploring concepts from relativity and quantum mechanics. Participants examine the implications of mass-energy equivalence for photons, particularly in different mediums, and the appropriate equations to use in these contexts.
  • One participant presents a rearranged form of Einstein's mass-energy equivalence equation, suggesting that since photons travel at the speed of light, their mass is zero, leading to an undefined energy-mass ratio.
  • Another participant argues that the initial premise is incorrect for photons and refers to the FAQ for clarification.
  • A later reply expresses frustration at the lack of constructive help and requests the correct equation for photons.
  • Some participants discuss the different types of mass (rest mass, invariant mass, relativistic mass, gravitational mass, and inertial mass) and their implications for understanding photons.
  • One participant suggests that the energy of a photon can be expressed using the equation E = hv, indicating the need to apply quantum mechanics rather than relativity due to the undefined nature of 0/0.
  • Another participant asserts that the energy-mass ratio of photons is infinite, based on their interpretation of the equations involved.
Participants do not reach a consensus on the correct approach to understanding the mass and energy of photons. There are competing views on the appropriate equations and concepts to apply, and some participants express confusion and frustration over the responses received.
There is ambiguity regarding the definitions and implications of different types of mass as they relate to photons. The discussion also highlights the challenge of applying classical equations to quantum entities like photons, particularly in terms of undefined mathematical expressions.
JDude13
[STRIKE]If we rearrange Einstein's mass-energy equivallency equation we get.
[tex]m=\frac{E\sqrt{1-\beta^{2}}}{c^{2}}[/tex]
A photon moves at the speed of light making its beta=1. This would make its mass=0.
This would insinuate that in the original equation
[tex]E=\frac{mc^{2}}{\sqrt{1-\beta^{2}}}[/tex]
[tex]E=\frac{0}{0}[/tex]
[tex]\frac{0}{0}[/tex] equals every other number (if my research serves me correctly). Is this why photons can have many frequencys/energies?
However; a photon is only moving at c in a vacuum. What happens in other mediums? Does a photon gain mass? And, if so, what happens to its energy?
Please don't bite my head off for not grasping some seemingly-easy topics. I'm still only young.[/STRIKE]
What is the equation to figure out the energy-mass ratio of photons?
Please start by reading one of the entries in the FAQ thread in the General Physics forum. The problem here is that you're starting off with the wrong premise/equation for photons.
Zz.
Well... That was helpful...
How about, instead of "You're doing it wrong" *silence*, you actually help. My post was a question which you have failed to answer.
I did answer it! You are starting off with the wrong equation that wasn't meant to be used for photons! Isn't that clearly stated in the FAQ? Or did you not even read it?
This is a VERY common question that we get on here. That is why it is in the FAQ! If you've read it, and still have something you didn't understand, then that's when a followup discussion on here will be appropriate!
Zz.
Could you please tell me the correct equation, then?
Why is the equation different to other particles?
Also, I told you not to bite my head off.
I also know what it says in the FAQ about overly-speculative posts.
Er... the FAQ contains NOTHING about "speculative post". You are confusing the FAQ with the PF Rules!
The FAQ thread, IN THE GENERAL PHYSICS FORUM, can be found here (in case you were lost in your search):
https://www.physicsforums.com/showthread.php?t=104715
This link is also listed in one of the Sticky thread in the Relativity forum titled "IMPORTANT! Read before posting".
Zz.
There is rest mass, invariant mass, relativistic mass, gravitational mass, and inertial mass. Not all of these are equivalent to each other. First, figure out which one you are interested in.
Since you specify mass=0 then you are talking about the invariant mass (usually the best mass from K^2's list to talk about these days). Since the mass is zero and division by 0 is undefined the "X to mass" ratio is going to be undefined regardless of what X is.
Why not simply say:
Energy of Photon = h v (h is Plank's constant, v is the frequancy ,here we must use quantum mechanics because we can not find the energy of the photon using relativity because 0/0 is unknown)
Mass of Photon = 0
hv/0 = infinity (often symbolically represented by ∞) .
o/o is undefined but X/o is defined it equals infinity.
so energy-mass ratio of photons = ∞
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 55 ·
  • · Replies 26 ·
  • · Replies 17 ·
