| New Reply |
Average distance for network topologies. |
Share Thread |
| Jan20-11, 12:39 PM | #1 |
I want to derive a general formula to calculate the average distance of the nodes in a network topology. The topologies can be line(linear), ring, mesh etc. The different nodes are numbered 0,1,2.. N-1. I understand the diameter of the network etc. 2. Relevant equations None. 3. The attempt at a solution I am doing self study and the book simply provides the formula without any proofs. I am not sure what are the techniques or where to start to solve it. |
| Jan20-11, 01:50 PM | #2 |
Perhaps the formula is intuitively understandable?
| Jan21-11, 10:19 AM | #3 |
Well the book says the average distance is roughly (2/3)N for a linear bi directional linked network. Its does not seem intuitive for me. Can you please provide some hints?
| Jan21-11, 02:53 PM | #4 |
Hmm. In case of unidirectional link the average distance of a ring I think I could derive as follows:
The sum of distance of a node to all other nodes : 0+1+2+3..+n-1 = n(n-1)/2 Total number of distances : (n-1). Average distance : n(n-1)/2 /n-1) = n/2. Please verify. Now got to figure out bidirectional links and linear array. |
| Jan21-11, 05:52 PM | #5 |
I'm thinking that in a unidirectional ring, the round-trip distance is the whole ring, so the average round-trip distance is the whole ring, or N. In a bidirectional ring, every node is like the center node in a bidirectional linear network. That case should be easier to understand than the linear case.
I'll think some more about this. (You're right, it isn't intuitive.) |
| Jan21-11, 06:31 PM | #6 |
Have you got enough to go on? The linear case becomes much easier to understand if you experiment with small numbers of nodes.
| Jan24-11, 05:50 AM | #7 |
In case of linear link is there any hint I can use? The smaller sums tend to be the following: For a 3 node linear link: Distances from 1 {1,2} 2 {1,1} 3 {2,1} Generalizing 1 {1..n-1} 2 {1,1..n-2} 3 {2,1,.., n-3} . . n {n-1,.. 1} Turns out the distances form a symmetric matrix. Now is there any properties of matrices I can use to get the sum of the distances? |
| Jan24-11, 07:09 AM | #8 |
I don't want to say too much because I think you can solve this, but I'll give a hint:
2 nodes: 11 3 nodes: 12, 11, 21 or 11, 2112 4 nodes: 123, 112, 211, 321 or 11, 2112, 321123 |
| Jan24-11, 01:01 PM | #9 |
Am I in the right path if I do this?
(1+1) + (2+1+1+2) + (3+2+1+1+2+3) i.e. 2 * n * (n-1)/2 = n*(n-1). Hence the sequence n(n-1) + (n-1)(n-2)+.... n*n2 - n[1+3+5] + [2 + 6 + 12...] |
| Jan24-11, 02:57 PM | #10 |
Do you recall that you were trying to find the average distance? If you know the sum of distances, then...
| Jan25-11, 12:54 AM | #11 |
In case of 4 nodes then the average distance is 20/12. (The total number of distances will be n*(n-1)) |
| Jan25-11, 06:24 AM | #12 |
So the rest is up to you. The last hurdle was the number of nodes but you have a formula for that, so you have all the ingredients. Now just find the answer, what is the average distance versus N nodes? |
| Jan25-11, 06:54 AM | #13 |
I am sorry , I am confused. I am not able to find the sum of the distances for N nodes. I have distances for 2,3,4.. nodes. I am failing to see how I have enough ingredients here :(
| Jan25-11, 07:05 AM | #14 |
You don't need a generic formula for N nodes. Find the average distance for 2,3,4,...
(You'll see, it works out pretty nicely.) |
| Jan25-11, 08:01 AM | #15 |
I think I can see it now. 1,1.3,1.6.. difference is ~ 0.3
So the formula would be 0.7 + 0.3n ? |
| Jan27-11, 01:03 PM | #16 |
Vertigo,
Am I right? If not can you provide me some more hints? |
| Jan27-11, 04:21 PM | #17 |
That formula is not correct. It works only for small numbers of nodes. Can you see why?
| New Reply |
| Tags |
| average, distance, network, topology |
Similar discussions for: Average distance for network topologies.
| Physic average distance | Introductory Physics Homework | 1 | ||
| Average distance between two points on sphere! | Calculus & Beyond Homework | 0 | ||
| Average distance between water molecules | Introductory Physics Homework | 3 | ||
| average velocity with respect to distance | Introductory Physics Homework | 2 | ||
| average distance at STP | Introductory Physics Homework | 5 | ||
