Path of light@ various distance from Black Hole
The discussion revolves around the behavior of light near a black hole, specifically focusing on what a sensor on a small bot would record as it approaches the black hole. Participants explore the implications of light bending and the visibility of distant stars in the absence of obstacles around the black hole.
  • Homework-related
  • One participant questions the path of light at various distances from a black hole and what a sensor would record before encountering the blackness of the black hole.
  • Another participant describes a cone of light that changes as one approaches the black hole, mentioning the photon sphere and event horizon.
  • A participant suggests that the last thing the sensor would record is a point of light, likening it to a disappearing dot on an old television set.
  • One participant expresses confusion regarding the sensor's ability to record light, noting that the only light source is the bot itself.
  • Another participant proposes that the last thing recorded could be multiple images of surrounding stars due to light bending around the black hole.
  • There is a discussion about whether the light emitted from the bot could also bend and contribute to the visibility of stars.
  • Some participants express uncertainty about the nature of the light recorded, questioning whether it would be multiple stars or a "light-smear" effect around the black hole.
Participants do not reach a consensus on what the sensor would ultimately record, with multiple competing views on the nature of light bending and visibility near the black hole remaining unresolved.
Participants acknowledge limitations in their understanding and the assumptions made about the light sources and the environment around the black hole.
Astro.padma
Have some doubt regarding the behaviour of the light near the Black hole...What happens to the path of light at various distances from the Black hole??...If we send a small bot, with sensor attached to it , radially towards the Blackhole, what would be the last thing that the sensor records before it perceives the blackness of the black hole?
to avoid complexities, let's assume that there is no dust or any obstacle kind of thing around the BH :)
Astronomy news on Phys.org
welcome to pf!
hi pranathi! welcome to pf! :smile:
from any distance, there is a cone in front of you from which no light comes
as you approach the black hole, the angle of that cone gets larger
at the photon sphere (r = 3M, where the event horizon is at r =2M), the cone has a solid angle of 2π … ie it's flat
between the photon sphere and the event horizon, the solid angle is more than 2π, and loosely speaking you're now "inside" the cone: instead of a small black cone in front you, and everything else is light, there's a small light cone behind you, and everything else is black!
when you reach the event horizon, the light cone has reduced to zero :redface:
(i should add that on the edge of the cone, there could be a "caustic" of bright light, caused by light from far away circling the black hole many times close to the photon sphere before finally escaping again)​
Thank you ... Sir :)
I got some idea with what you have posted and regarding this ?
"If we send a small bot, with sensor attached to it , radially towards the Blackhole, what would be the last thing that the sensor records before it perceives the blackness of the black hole?"
hi pranathi! :wink:
the last thing will be a photo of a point of light in the direction it came from (rather like the disappearing dot we used to have in really old television sets!)
oh, and don't call me Sir! … i'm only a little goldfish! :smile:
Ok Tim ... Thanks for it anyways and am new to pf ... and this is my homework question but unable to relate your answer to my homework :( So can I post my question, here?
An alien civilization has sent a small Spherical bot, made of Sterling Silver,
fitted with a light emitter and sensor as depicted below, towards a black hole
to explore the region around it. The bot moves slowly towards the black hole,
radially into it. The light source emits light in such a way that it
is tangential (at
the pt. of emission) to a circle with ‘centre of black hole’ as its
centre, and the
distance between the black hole and the centre of the bot as its radius. The
region around the black hole is free of dust or any other obstacle, and there
are no other light sources anywhere nearby which can be perceived by the
sensor.
Due to some malfunction, the sensor of the bot receives only those signals,
which fall onto it radially.
What will be the last thing that the sensor records before it perceives the
NOTE : The effect of gravity of any other bodies other than the black hole on
the bot is negligible
My doubt is...when we don't have any obstacle or dust kind of thing around the black hole, wat can the sensor record?
The only light source in this question is the so called "light emitting area" ... So what i thought is the last thing would be the multiple image of surrounding stars as the light bends around the Black hole...
Is it alright or am I going wrong anywhere??
i agree with you … the question seems to be saying that the sensor can only record light from the probe itself …
and since there's no dust to reflect the light back, that presumably means that it doesn't see anything at all for most of the journey (except the distant stars)
what about the light from the probe bending?
(btw, in future please put your homework questions in the https://www.physicsforums.com/forumdisplay.php?f=152")
Then is the answer multiple images of stars?
Dint get you tim...what is probe bending?
n yeah i will post them in homework thread :)
the light bends!
Yeah am talking about the light bending only...The multiple images of surrounding stars is due to the bending of light only !
i am talking about the light from the probe bending!
aint getting you tim...why would the probe bend? unable to understand such a scientific language ! :cry:
the light bends …
the light (from the probe) bends :rolleyes:
:( the light from the probe only should cause the multiple images of stars :O
Why do you believe that?
Nismarath...because there is no other source of light except that emitted by the bot in our present situation and so, the light from the bot should bend around the black hole, thus giving us multiple images of surrounding stars... :(
Would it be MULTIPLE stars, or just a kind of "light-smear" around the BH? I think it would be like seeing the light mapped on a torus... not actually that, but a similar effect.
Um...not convinced...:frown:. but still thanks for d replies tim n nismarath :smile:
I'm not sure either, so I don't blame you! :smile:
  • · Replies 20 ·
  • · Replies 51 ·
  • · Replies 17 ·
  • · Replies 37 ·
  • · Replies 35 ·
  • · Replies 43 ·
9K
  • · Replies 64 ·
