New Reply
Moment of inertia of hollow cylinder, axis orthogonal to length
Share Thread Thread Tools
Jan22-11, 08:21 AM   #1
Hi, I am working through the Feynman lectures on physics and trying to calculate the moment of inertia stated in the title.
(the taxis of rotation going through c.m., orthogonal to length).
My approach is to slice the cylinder into thin rods along the length, using the parallel taxis theorem and the result for a rod.
Unfortunately, I get as result: I = M ( L^2 / 12 + r^2 / 2). I.e. the last numerator comes out as 2 instead of 4, as stated in section
19-2. The corresponding expression comes from summing up dm sum( z_i ^ 2), where dm is the mass of a single rod and z_i
the height of the rod's center of inertia. Perhaps my mistake lies in handling the 2-dim slices as 3-dim rods?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jan22-11, 08:48 AM   #2
K^2
Recognitions:
I would slice the cylinder into rings instead. It makes integration far easier.
Jan22-11, 09:14 AM   #3
Mentor
Quote by jds17 View Post
My approach is to slice the cylinder into thin rods along the length, using the parallel taxis theorem and the resultat for a rod.
Unfortunately, I get as result. I = M ( L^2 / 12 + r^2 / 2). I.e. the last numerator comes out as 2 instead of 4, as stated in section
19-4.
Your method looks OK to me. Feynman lists (in table 19-2) the moment of inertia of a solid cylinder.
Jan22-11, 09:38 AM   #4
@Doc Al: Thank you for your reply, I took the cylinder as a hollow one, and this seems to be my mistake. I will try
to do the calculation again for the solid cylinder as soon as I get back home.
@K^2: thank you, too, but I wanted to find out what was wrong with my thinking instead of doing a different
calculation. I will try yours, too, although it seemed more complicated when I first considered it
Jan22-11, 02:18 PM   #5
Hi, everything turned out nicely, considering a partition into concentric hollow cylinders, adding their M.I.s (calculated as before) up and going to the limit gives the answer in table 19-2!
New Reply
Tags
classical mechanics, moment of inertia
Thread Tools
Similar Threads for: Moment of inertia of hollow cylinder, axis orthogonal to length
Thread Forum Replies
Moment of inertia of a hollow sphere Introductory Physics Homework 14
Moment of Inertia on Semi-Hollow Cylinder Introductory Physics Homework 2
Moment of Inertia of Hollow Sphere Advanced Physics Homework 2
Moment of inertia for a cylinder at a distance from rotation axis Introductory Physics Homework 1
