How do I solve for gravitational force and tension in physics?
  • Thread starter Thread starter matchboxdude
    Physics
The discussion revolves around calculating gravitational force and tension in physics problems involving a spaceship and a car towing a boat. The original poster seeks assistance with two distinct scenarios: one involving gravitational interaction between two parts of a spaceship and another concerning the tension in a towing scenario.
  • The original poster attempts to apply the gravitational force formula but questions the correctness of their approach after receiving an incorrect answer. They also express uncertainty about the appropriate method for calculating tension in the towing scenario.
  • Some participants clarify the distinction between weight and mass, suggesting the need to convert weights into masses before using the gravitational formula.
  • Others provide equations for acceleration and force, exploring how to apply these to the towing problem.
Participants are actively engaging with the problems, offering clarifications and alternative approaches. Some guidance has been provided regarding the conversion of weights to masses and the calculation of acceleration, but the second problem remains less explored, with the original poster expressing uncertainty about how to proceed.
The original poster indicates a lack of familiarity with physics concepts, which may affect their understanding of the problems. There is also mention of previous incorrect answers, suggesting that assumptions or methods may need reevaluation.
matchboxdude
I have a few questions that I desparately need help with. I'm new to this physics thing and it is really getting me.
On Earth, you have two parts of a spaceship with weights 19000N and 5100N. They are separated center to center by 10m and are uniform spherical objects. what is the magnitude of the gravitational force that each part exerts on each other out in space, far from everything?
I figure i would use F=(G*m1*m2)/r2 / F=(6.67E-11*19000*5100)/10^2 , but i got the question wrong. So, I don;t know my other options...
Then another question is...
A car is towing a boat on a trailer. The car starts from rest and accelerates to a speed of 12m/s in 18seconds. The combined mass of the boat and trailer is 490kg. What is the tension in the hitch that connects the trailer to the car?
I have an equation from a different problem, but I'm not sure if it works for this problem. T + 9.8 = mass*accelleration. But using this gives me an incorrect answer. So I assume I am going in the wrong direction again.
Thanks ahead of time for any help.
#1 m1 and m2 are the masses of the parts of the spaceship not their weights.
ahh that would make a difference. so would i use Weight = (G* Mass of Earth* mass of object)/radius of the earth^2 to get the masses then plug then into the formula i mentioned earlier?
i mean you have to convert their weights into masses first before you put them into the formula. W=mg where
W= weight of part
m= mass of the part
g = the gravity acceleration on Earth = 9.81 meter per second per second
ok i did that, plugged the numbers back into the original equation and got 6.73e-7 N does that sound like it could be correct?
i went ahead and used that answer and got it correct. thank you very much. how about that second problem? i don't have any clue where to go with it
The acceleration a for the car and the trailer is given by (Assume a is constant through the towing):
[tex]a=\frac{v-u}{t}[/tex]
[tex]a=\frac{12-0}{18}[/tex]
a=2/3 meter per second per second
Consider the boat & trailer :
[tex]\Sigma\vec{F}=m\vec{a}[/tex]
[tex]T=m_{trailer\&boat}*a[/tex]
T= 490*(2/3) = 327 N
11K
