Determine velocity of a mass suspended from a stretched spring
The discussion revolves around determining the velocity of a mass attached to a spring as it moves through different positions after being released from a stretched state. The subject area includes concepts from mechanics, specifically energy conservation in spring systems.
  • Participants discuss using energy conservation principles to relate the potential energy stored in the spring to the kinetic energy of the mass. There are attempts to derive equations for the mass's speed at various points of spring extension.
Some participants have provided guidance on applying energy balance equations, while others are exploring the implications of frictionless conditions. There is a mix of interpretations regarding the correct application of energy conservation, particularly in the second part of the problem.
Participants are operating under the assumption of no friction and are questioning the definitions and implications of potential energy in the context of the problem. There are indications of confusion regarding the application of formulas and the interpretation of variables.
physicsss
A mass m is attached to a spring which is held stretched a distance xmax by a force Fmax , and then released. The spring contracts, pulling the mass. For the following answers, assume that there is no friction. Use m for the mass, x for the distance xmax and F for the force Fmax.
(a) Determine the speed of the mass when the spring returns to its normal length (x = 0).
(b) Determine the speed of the mass when the spring returns to half its original extension (x = xmax/2).
a) You should have an equation for the energy stored in the spring as a function of the spring constant and the distance it's stretched. If the surface is frictionless, then all of the energy in the spring will appear as kinetic energy in the mass. Do an energy balance.
b) Ditto.
No friction?? only Conservative Forces, great!
Conservation of Mechanical Energy
[tex]\Delta K + \Delta \Omega = 0[/tex]
or
[tex]\Delta E = 0[/tex]
what does Omega mean?
Sorry, i was busy, it means Potential Energy.
For the first part is it 1/2mv^2=1/2kx^2, solve for v i got v=sqrt(kx^2)/m
, substituting kx for f i got sqrt(Fx/m). This is right.
But for part b, 1/2mv^2=1/2k*(x/2)^2, and when I carried this all out, I got v=1/2*sqrt(Fx/m)...but I got it wrong.
Your second equal makes no sense...
You should use the point where it's at its max potential energy (max length) and equal it to its energy at half lenght.
[tex]\frac{1}{2}kx_{max}^{2} = \frac{1}{2}mv^2 + \frac{1}{2}k(\frac{x_{max}}{2})^{2}[/tex]
  • · Replies 31 ·
