Ohmic junction in Cat's-whisker detector
  • Thread starter Thread starter wasia
    Detector Junction
wasia
Hello,
I have read (wiki and physicsforums besides other sources) about how preparing an ohmic junction is hard on wafers in the clean room and that usually one gets a Schottky barrier instead, if one is not careful enough. This makes me wonder, how come that people used to get an ohmic contact on the ancient"[URL detector[/URL] by just "clamping (the crystal) with setscrews" ?
Or if I am wrong with my assumptions and it is not an ohmic contact, just a random collection of p-n junctions, why does the device work at all?
Thanks in advance.
Technically, only one contact should be rectifying (the springy one). The other should be ohmic. Clamping down is a sort of brute-force way to make ohmics. You have a very large area and the surface gets ground up which removes the surface layer (oxide or whatever). Eventually, electrons might find an ohmic or quasi-ohmic path. And if it doesn't work, you wiggle it some more. But in some cases, you will never get a properly ohmic contact. It depends on the material, doping, etc.
And I'm pretty sure the specs were much lower then. They could live with higher-resistance contacts, as long as they were more or less linear. Now we need the contacts to have a low resistance and work reliably every time (especially in production).
I suggest a method usually used in our experiment.
Depositing Au film on the sample first, and then you have 2 choices:
1. sticking the detecting wire by sliver adhesive.
2. preparation with the indium electrode.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
9K
12K
10K
27K
