What is the initial velocity of the stone?
The discussion centers on a physics problem involving projectile motion, where a boy uses a slingshot to launch a stone at a can positioned 15 meters away at a 30-degree elevation. The initial velocity of the stone is calculated to be 19.05 m/s in the x-direction and 11.0 m/s in the y-direction. The stone passes directly below the can after 0.682 seconds, with a height differential of 2.28 meters between the can and the stone's trajectory. The range of the stone is determined to be 14.0 meters, indicating that the aim was off.
  • Understanding of projectile motion principles
  • Familiarity with vector components in physics
  • Knowledge of kinematic equations, specifically y = v_{0y}t - (1/2)gt^2
  • Ability to perform calculations involving trigonometric functions for angles
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn how to resolve vectors into their x- and y-components
  • Explore the effects of different launch angles on projectile range
  • Investigate the impact of initial velocity on the trajectory of projectiles
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of objects in motion.
buffgilville
Can anyone tell me if my answers are right or wrong? thanks
A boy with a slingshot wants to hit a can on top of a pole. The can is a distance of 15 meters from the boy at an elevation of 30 degrees above the horizontal. The boy aims the slingshot directly at the can and projects a stone with a speed of 22 meter/second. It misses the can. (We want to find out bad the aim was.)
a) Find the x- and y- components of the displacement of the can from the child.
12.99 x + 7.50 y
b) What is the initial velocity of the stone?
19.05 x + 11.0 y
c) When does the stone pass directly below the can?
0.682 seconds
d) Find the height differential between the can and the path of the stone.
2.28 meters
e) Find the range of the stone (i.e. where it lands).
14.0 meters
Look over (d) and (e) more carefully. The rest of your answers look good. For (d) you will need to use:
[tex]y = v_{0y}t - \frac{1}{2}gt^2[/tex]
For part (e) you can use the same equation and solve for t when y = 0. That will give you the total time of flight. You can then find the range via
[tex]x = v_{0x}t[/tex]
Without knowing the specific values used in the calculations, it is difficult to determine if the answers are right or wrong. However, the method and formulas used seem to be correct. It is always a good idea to double check your calculations and make sure they are consistent with the given information and formulas. Additionally, it may be helpful to have someone else check your work to ensure accuracy.
12K
