Real Analysis - Simple supremum/infimum problem
The discussion centers on finding the supremum and infimum of the set S = {1/n - 1/m | n, m ∈ N}. The supremum is established as 1, while the infimum is derived from the properties of the subsets {1/n} and {-1/m}. The participants emphasize the use of the epsilon argument and the Archimedean property as effective methods for tackling supremum and infimum problems. The conclusion is that the supremum of S is 1 and the infimum is -1.
  • Understanding of supremum and infimum definitions in real analysis
  • Familiarity with the Archimedean property
  • Knowledge of epsilon-delta arguments
  • Basic set theory involving subsets of real numbers
  • Study the epsilon-delta definition of limits in real analysis
  • Explore the Archimedean property and its applications in proofs
  • Learn about the properties of bounded sets in real analysis
  • Investigate the relationship between supremum and infimum in the context of set operations
Students of real analysis, mathematicians focusing on set theory, and anyone looking to deepen their understanding of supremum and infimum concepts in mathematical analysis.
rolandc
If S = { 1/n - 1/m | n, m [tex]\in[/tex] N}, find inf(S) and sup(S)
I'm having a really hard time wrapping my head around the proper way to tackle sumpremum and infimum problems. I've included the little that I've done thus far, I just need a nudge in the right direction. Correct me if I'm wrong but I gather that there are basically 2 ways to tackle these problems.
1. An "epsilon" argument using the definition of supremum/infimum
2. An argument using some variation of the archimedean property
N/A
S is bounded above by 1. Therefore, S has a supremum. Let u = sup(s). We know that u <= 1. We will show that u = 1 by proving that u cannot be less than 1.
Assume u < 1.
1/n - 1/m <= u < 1
Where do I go from here? Thanks.
Intuitively you should see that the candidates for inf and sup are -1 and +1, respectively. You've got the right idea for the proof.
By definition, you have to show any upper bound u for S has 1 <= u. To do this, try to exhibit an element of the set that is strictly bigger than u if you assume u < 1.
N/A
Assume u < 1.
1/n - 1/m <= u < 1
You could first prove that if [itex]S_1 \subseteq \mathbb{R}[/itex] and [itex]S_2 \subseteq \mathbb{R}[/itex] and you define [itex]S = S_1 + S_2 = \{ x+y : x\in S_1, y\in S_2 \}[/itex] then [itex]\text{sup}(S) = \text{sup}(S_1) + \text{sup}(S_2)[/itex] .
Then you can read off the supremum of [itex]\{1/n - 1/m : n, m \in \mathbb{N} \} = \{1/n : n \in \mathbb{N} \} + \{-1/m : m \in \mathbb{N} \}[/itex] easily.
A similar proof would yield [itex]\text{inf}(S) = \text{inf}(S_1) + \text{inf}(S_2)[/itex] and again you can read off the infimum of the set you want very easily after deducing this result.
[by the way the sup and inf's of [itex]\{1/n : n \in \mathbb{N} \} ,\{-1/m : m \in \mathbb{N} \}[/itex] are not [itex]\pm 1[/itex] ]
9K
  • · Replies 16 ·
