Integration of incomplete gamma function
The discussion revolves around the integration of the incomplete gamma function in a specific integral involving a Gaussian function. Participants explore methods for performing this integration, particularly focusing on the case where the parameter \( k \) is an integer.
  • Homework-related
  • Alex seeks assistance with the integration of the incomplete gamma function multiplied by a Gaussian function, indicating difficulties with computational tools like Mathematica.
  • Jason suggests that if \( k \) is an integer, the incomplete gamma function can be expressed as a polynomial times an exponential, and recommends completing the square in the exponent to simplify the integration.
  • Jason notes that this approach leads to a finite sum of moments of a Gaussian, which could be referenced from existing literature, but acknowledges that the resulting expressions may be complex.
  • Alex confirms that \( k \) is indeed an integer and expresses intent to follow Jason's suggestion, but later seeks clarification on completing the square and expresses uncertainty about the integration process.
  • Alex questions whether there are alternative approximations for the upper incomplete gamma function to facilitate the integration.
Participants generally agree on the approach of using properties of the incomplete gamma function when \( k \) is an integer, but there is uncertainty regarding the specifics of completing the square and alternative methods for integration. The discussion remains unresolved as participants have not reached a consensus on the best approach to proceed.
There are limitations regarding the assumptions made about the parameters involved, particularly the nature of \( k \) and the complexity of the integrand. The discussion does not resolve the mathematical steps required for the integration.
architect
Hi,
I am interested in performing the following integration:
[tex]\int _{-\infty }^{\infty }\Gamma\left[k,\frac{x+u}{v}\right]e^{-\frac{(x-m)^2}{2\sigma ^2}}dx[/tex].
I would appreciate anyone's help. I have been trying to do it in Mathematica but it runs out of time returning the same integral.
Thanks in advance.
Alex
is [tex]k[/tex] and integer? If so, then the incomplete gamma function is a polynomial times an exponential:
http://en.wikipedia.org/wiki/Incomplete_gamma_function
so you just complete the square in the exponent and you have a finite sum of moments of a Gaussian, which are easy to look up
http://en.wikipedia.org/wiki/Normal_distribution
Of course this will be very messy to write out, and at the end you will have a finite sum of confluent hypergeometric functions (which may not be useful to you at all) but it is doable. Nicer forms may be possible, too.
For arbitrary [tex]k[/tex] this is really hard, I think.
good luck,
jason
jason
Thanks, your comment was helpful about the moment generating function of a Gaussian.
k is an integer in my case. I will give it a try.
Best Regards,
Alex
I tried to do what you suggested, but I am not sure how to proceed in completing the square. In case, [tex]k[/tex] is an integer we get the polynomial as you said times [tex]e^{-x+u/v}[/tex]. The other part of the integrand is a Gaussian exponent. Therefore, I do not see how to proceed especially since the moment of a Gaussian is obtained via the Fourier transform. The first exponent in my case is not complex.
Can I approximate the upper incomplete Gamma function [tex]\Gamma[k,\frac{x+u}{v}][/tex] in some other way in order to then be able to perform the integration?
Thanks again.
  • · Replies 27 ·
