Does density change with temperature and how would you calculate it?
  • Thread starter Thread starter nemzy
    Density
The discussion revolves around the relationship between temperature and the density of gasoline, specifically whether density changes with temperature and how to calculate that change. The subject area includes concepts of density, volume expansion, and thermal properties of materials.
  • Participants explore whether density remains constant or changes with temperature, with some discussing the impact of volume changes due to thermal expansion. Questions arise about how to calculate the new density at different temperatures using coefficients of volume expansion.
Participants are actively engaging with the problem, with some providing equations related to volume change and discussing how to relate volume changes back to density calculations. There is a clear exploration of the relationship between mass, volume, and density, but no consensus has been reached on the final calculation method.
Participants mention specific values such as the density of gasoline at 0 degrees Celsius and the average coefficient of volume expansion, indicating that these parameters are part of the homework context. There is an emphasis on using provided coefficients and initial conditions to explore the problem further.
nemzy
lets say for example the density for gasoline is 730 kg/m^3 at 0 degree Celsisus
Will the density be different for at a diff temperature, or will it always remain constant?
If it is different, how would you calculate it? thanks
Density is mass per unit volume (well, mass density anyways)
So heating or cooling would change the density beucase the volume that the substance would change. There are a number of different ways to find the change in volume of the substance...depending on what form it is in, etc.
well for my homework question, it gives the avg coefficient of volume expansion. and from there on i have no idea how to calculate the density of gasoline at a diff temp.
use the following equation:
[tex]\Delta V = \delta*V*\Delta T[/tex]
Where [tex]\Delta V[/tex] is the change in volume, [tex]\delta[/tex] is the coefficient of volume expansion, V is the current volume, and [tex]\Delta T[/tex] is the change in temp
Edit: Changed symbols to Latex
i know, but once u find the change in volume, how can u relate it to finding density at a certain temp?
for example, let's say density of gasoline is 730 kg/m^3 at 0 degrees
what will the density be at 20 degrees?
a gallon of gasoline occupies .00380 m^3 and the avg coefficient of volume expansion is 9.6e-4
So plugging it into the equation, i got a change of volume of 7.296e-5, with final volume being .00387296...now from here how would i be able to find the new density at the new temp?
well, remember, mass density = mass / volume
you know the new volume...and you know the mass (hint: use the original density and the original volume to find the mass)
  • · Replies 84 ·
9K
  • · Replies 29 ·
