| New Reply |
Ideal material for Golf application |
Share Thread | Thread Tools |
| Jan28-11, 12:22 PM | #1 |
I'm currently in the process of designing a golf application. Because of what it is, it needs the following properties:Corrosion resistance, UV resistance, lightweight, and heat resistance although this is not essential as I could use a heat shield, I believe mica would be ideal for this.
So if anyone could suggest a metal or plastic with these proerties it would be very helpful. Thanks |
| Jan28-11, 12:28 PM | #2 |
If you could be specific about the type of application, you'd be FAR more likely to get some help. You've left it very open-ended.
| Jul6-11, 11:25 AM | #3 |
Even though em not 100% what type of application u are trying to develop but for heat release I can give u suggestion to use Au. I mean Pure Aluminum. It is used in Computers with a cooler fan and so it is the best materiel for releasing heat from ur device. Another important benefit is this metal is cheap and light weight. So its excellent for personal research and portable devices.
Hope this helps. Thanks Gorge. Golf Lessons Livemore |
| New Reply |
| Tags |
| corrosion, metal, plastic, resistance, resistant |
| Thread Tools | |
Similar Threads for: Ideal material for Golf application
| Can someone tell me what is the best collimation material for this application? | General Physics | 5 | ||
| Ideal gas law practical application | Advanced Physics Homework | 5 | ||
| Ideal rocket equation application help | Advanced Physics Homework | 0 | ||
| [SOLVED] Ideal Gas Law Application | Introductory Physics Homework | 3 | ||
