What is the height of the chimney?
  • Context: Undergrad
  • Thread starter Thread starter Rocko
The discussion revolves around determining the height of a chimney using trigonometric principles based on angles of elevation measured from three survey stations. The problem involves geometric relationships and projections in a horizontal plane, with participants exploring various methods to approach the solution.
  • One participant suggests using trigonometric functions to find horizontal projections from each survey station to the top of the chimney, expressing the lengths in terms of the unknown height h.
  • Another participant elaborates on the approach by setting up equations based on the geometry of triangles formed by the survey stations and the chimney base, indicating that three equations can be derived to solve for the unknowns.
  • A different approach is proposed involving the cosine rule applied to the triangles formed by the survey stations and the chimney base, leading to two equations with two unknowns.
  • One participant mentions a potential solution for the height of the chimney as 34.191m, indicating they have worked through the problem after initial doubts about the complexity of the algebra involved.
  • A later reply humorously contrasts the perspectives of mathematicians and engineers regarding problem-solving, emphasizing a mathematician's tendency to acknowledge the existence of a solution without pursuing it further.
Participants express various methods and approaches to the problem, but there is no consensus on a definitive solution or agreement on the best method to use. The discussion remains exploratory with multiple competing views on how to tackle the problem.
Participants acknowledge the complexity of the algebra involved and the need for careful consideration of geometric relationships, but specific assumptions or limitations in their approaches are not fully resolved.
Rocko
Three survey stations X, Y, Z lie in one straight line on the same straight plane. A series of angles of elevation are taken to the top of a chimney which lies to one side of XYZ. The angles of elevation of the top of the chimney measured ay X, Y, Z are 14 degrees 02 ', 26 degrees 34' and 18 degrees 26' respectively. The lengths XY and YZ are 121.92m and 73.15m respectively. Find the height of the chimney.
Mathematics news on Phys.org
Trigonometry?
Yes Trig
Not just as simple as you think.
Rocko, I think I'd approach that problem by finding the length of each of the horizontal plane projections of the lines from X,Y,Y to the top of the chimney. Now these lengths will be in terms of the height h of the chimney.
L1 = h cot(angle1) and similarly for the other two. h is of course an unknown at this point but the cot()'s are all plain constants. You should find there is just one value for h that allows the lines of length L1 from X, L2 from Y, and L3 from Z to intersect at one point (that point being the base of the chimney). Once you get this point you're home free.
Just to elaborate on solving for the intersection of those horizontal projection.
Arbitrarly take points X,Y,Z lying on the x-axis with point Y at the origin. Then you get something like this,
(121.92+x1)^2 + y1^2 = a h^2
x1^2 + y1^2 = b h^2
(x1-73.15)^2 + y1^2 = c h^2
Here, a, b and c are constants (from the cot's squared) and (x1,y1) is the base of the chimney in the coords specified. Three equations and three unknowns = nice :)
I would start the same way as uart, but then, I'd do the following.
The projections in the ground plane are a pair of adjacent triangles : XCY and YCZ where C represents the base of the chimney.
The sides of these triangles are :
XY = known,
XC = h cot(angle1)
YC = h cot(angle2)
YZ = known
ZC = h cot(angle3)
Let angle <ZYC = alpha, then angle <XYC = 180 - alpha
Use the cosine rule for the two triangles with respect to the angles alpha and 180-alpha.
You have 2 equations in 2 unknowns.
after 3 days and many scrap pages i finally think i come up with a answer thanks Goku, you know i tried that method right off the start but thought the algebra would just be to complex to carry thru so i scrapped the idea, but after confirmation i knew it was what needed to be done did you get an answer for h= 34.191m?
Actually, I never did go about solving it. It's the typical mathematicians outlook : once you establish that the solution exists, you walk away from it.
There's a small fire accidentally started in your house and you have a large bucket of water. What do you do ?
Engineer : Pour the water over the fire and extinguish it.
Mathematician : You have a fire; you have the water. A solution exists. (and walks away)
:biggrin:
  • · Replies 17 ·
  • · Replies 22 ·
