Solution to Critical State Problem: Progress Requirement
  • Thread starter Thread starter prashantgolu
    State
The discussion revolves around the critical state problem in concurrent programming, specifically analyzing an algorithm proposed by Galwin for two processes. Participants explore the algorithm's compliance with the "progress" condition required for critical section management.
  • One participant describes an algorithm that involves a turn variable and a critical section, questioning how it fails to meet the progress condition.
  • Another participant points out the lack of context regarding the variable 'i' and the processes 'p0' and 'p1', suggesting that the algorithm's completeness is unclear.
  • A participant clarifies that 'turn' is initially set to 0 and that 'p0' and 'p1' represent two processes, indicating that the algorithm is designed for two processes only.
  • Another participant agrees that the algorithm does not satisfy the progress condition, providing a scenario where one process could indefinitely prevent the other from entering its critical section.
  • A later reply suggests the need for an atomic operation and introduces the concept of using a flag variable alongside the turn variable, referencing established algorithms like Dekker's and Peterson's for context.
Participants generally agree that the algorithm does not satisfy the progress condition, but there is no consensus on the implications or potential solutions, as some participants introduce alternative approaches without resolving the initial concerns.
The discussion highlights limitations in the provided algorithm, including missing assumptions about process behavior and the need for atomic operations to ensure proper synchronization.
prashantgolu
i read this as a solution to critical state problem in galwin
repeat
while turn!= i do no-op;
critical section
turn := j;
remainder section
until false;
now this algo does not meet the "progress" conditiion...
the book states the reason as...this requires strict alteration of processed in execution of their critical state
for ex...if turn =0 and p1 is ready to enter its critical section,it cannot do so...even though p0 maybe in its remainder section...
how can p1 be in its remainder section and turn still be 0...
how does this algo not meet the reqirement of progress?
Technology news on Phys.org
repeat
critical section
turn := j;
remainder section
until false;
As stated here, this doesn't make much sense. Is this just a part of an algorithm and you haven't shown us the rest? We don't know the value of i, so can't tell whether turn != i is true or false.
What are p0 and p1? They aren't mentioned in the algorithm you showed.
sorry...my fault...turn=0 initaially...and p0 and p1 are two processes...this algorithm is for 2 processes only...so turn can be 0 or 1...
Ya, it is true that the algorithm does not satisfy the condition of progress...
Imagine a case when p1 has entered its critical section. After executing, it turns the value of turn to 0 and exits. But the process p0 does not want to enter its critical section. So the value of turn would be set to 0 for ever. Even though if process p1 wants to enter its critical section again, it cannot do so, until process p0 wishes to enter its critical section.
Hence the condition of progress is not satisfied.
I hope I was able to explain you. Do let me know...:approve:
thanks a lot :)
  • · Replies 0 ·
