Equivalence Point Calculation: Joe's Question
  • Thread starter Thread starter josephcollins
    Equivalence Point
The discussion centers on calculating the Half Equivalence Point in titrations to determine pKa from the pH value. Joe inquires whether to halve the pH or the volume at the Equivalence Point. The consensus is that the Half Equivalence Point refers to neutralizing half the moles of the acid or base, not halving the pH or volume values. Therefore, the correct approach is to focus on mole ratios rather than volume measurements.
  • Understanding of titration concepts
  • Knowledge of pH and pKa relationships
  • Familiarity with mole ratios in chemistry
  • Graph interpretation skills for titration curves
  • Study the concept of Half Equivalence Point in titrations
  • Learn about calculating pKa from pH values
  • Explore mole ratio calculations in acid-base reactions
  • Review titration curve analysis techniques
Chemistry students, educators, and laboratory technicians involved in titration experiments and acid-base chemistry.
josephcollins
Hi ppl, I was wondering. I have found the Equivalence point from the graph of volume versus pH for a given titration. To determine the Half equivalence point for to calculate Pka=Ph, do I half the pH or the volume which I found for the Equivalence point initially? Thanks for any help, Joe
Chemistry news on Phys.org
Dear friend,
Half equivalence in titrations means that the half mole of total acid or base is neutralized; it is not the half of pH value. Volume may be incorrect, so I recommend that you stick to mole ratios.
12K
10K
