Acceleration of an object w/ mass vs. friction
The discussion revolves around a physics problem involving an object sliding on a surface with friction. The original poster presents a scenario where a 0.3 kg object experiences a friction force of 0.2 N and has an initial velocity of 2.7 m/s, seeking to determine the time it takes to stop and the duration of the slide.
  • Participants discuss the application of Newton's second law (F=ma) and suggest considering conservation of energy as an alternative approach. There are questions regarding the understanding of concepts related to acceleration and kinematic equations.
The discussion includes attempts to clarify the relationship between friction, acceleration, and time. Some participants provide guidance on how to approach the problem, while others express uncertainty about concepts that may not have been covered in their learning.
There is mention of a mental block experienced by the original poster, and some participants indicate a lack of familiarity with certain concepts, such as conservation of energy, which may affect their ability to engage with the problem fully.
Spaghett
An 0.3kg object slides across a surface, experiencing a friction force of 0.2N. If its initial velocity is 2.7m/s, how long does it take to stop and how long does it slide for?
F=ma
I know I'm just missing a simple step or solution, but I'm just at a complete mental block right now.
Spaghett said:
F=ma
Maybe you'd want to consider conservation of energy instead as it is a bit easier?
What do you mean? I don't think i ever learned that
Ah sorry, I didn't see that you need the time as well.
If you have the frictional force, what is the associated acceleration?
When the mass stops, what is the final velocity?
What kinematic equation do you know involves initial velocity, final velocity acceleration and time?
I figured it out guys, simple F=ma, just didn't know i could use the force of friction as F, thanks anyhow
  • · Replies 19 ·
9K
  • · Replies 16 ·
  • · Replies 18 ·
