Finding corrections to volume of a two-sphere in 3-sphere geometry
  • Thread starter Thread starter Raziel2701
    Geometry Volume
The discussion focuses on deriving the first-order correction to the volume of a 2-sphere in 3-sphere geometry, represented by the formula V=4πa³[1/2 arcsin(r/a) - (r/2a)[1-(r/a)²]^(1/2)]. Participants emphasize the importance of expanding both the arcsine and the other terms when r/a is much less than 1 (r/a << 1). The correct approximation for the volume is V ≈ (4πr³/3)[1 + corrections of order (r/a)²]. The challenge lies in understanding the nature of these corrections, particularly since the arcsine expansion yields odd powers.
  • Understanding of 3-sphere geometry
  • Familiarity with Taylor series expansions
  • Knowledge of trigonometric functions, specifically arcsine
  • Basic concepts of asymptotic analysis
  • Study Taylor series expansion techniques for trigonometric functions
  • Explore asymptotic analysis in higher-dimensional geometry
  • Learn about corrections in geometric volume calculations
  • Investigate the properties of 3-sphere geometry and its applications
Mathematicians, physicists, and students engaged in advanced geometry, particularly those working with higher-dimensional spaces and volume calculations.
Raziel2701
Given the volume of a 2-sphere in a 3-sphere geometry,
[tex]V=4\pi a^3[\frac{1}{2}\arcsin (r/a) -\frac{r}{2a}[1-(\frac{r}{a})^2]^{(1/2)}][/tex], derive the 1st order correction when r/a<<1
I am also given that this is approximately [tex]V\approx\frac{4\pi r^3}{3}[1+()][/tex]
where inside the blank parenthesis should read "corrections of order (r/a)^2
So since r/a<<1 I figure that the only important term should be the arcsine and that I should expand it, but if I neglect everything but the arcsine I don't get the approximate expression, I just get the 4pir^3 times the first few terms of the arcsine expansion, not to mention that I am not entirely sure what is meant by corrections of order (r/a)^2 since the arcsine expansion has odd powers.
Hi Raziel2701! :smile:
(have a pi: π and a square-root: √ and try using the X2 icon just above the Reply box :wink:)
But arcsine(r/a) is approximately r/a, so it's almost the same size as the other part :confused:
you need to expand both of them :redface:
  • · Replies 105 ·
13K
  • · Replies 54 ·
