Vector subspace F is closed in E
The problem involves proving that a vector subspace F of bounded functions, defined as those functions that approach zero as n approaches infinity, is closed within the vector space E of bounded functions. The context is set within the framework of functional analysis, specifically dealing with norms and metrics.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the definition of the subspace F and question whether it is correctly stated. There are attempts to clarify the conditions under which F is considered closed, particularly in relation to vector addition and scalar multiplication.
The discussion is ongoing, with participants providing insights into the nature of closed sets in the context of vector spaces. Some suggest focusing on the limit properties of sequences in F to establish closure, while others express uncertainty about the original poster's proof and seek further clarification.
There are indications of potential typos and misunderstandings regarding the definitions used in the problem. Participants are also considering the implications of closure in terms of the sup norm topology.
Demon117
Let E be the vector space of bounded functions f:N --> R, with the norm(g) = sup|f|. Assume without proof that the norm holds, so that the function d(f,g)=norm(f - g) is a metric.
Prove that the vector subspace F={f in F | f(n) -->0 as n --> infinity} is closed in E.
Here is what I have come up with:
Consider the sequence (f_k) in F, such that f_k --> f. It must be shown that f is in F also.
For such (f_k) in F, it follows that (f_k)(n) -->0 as n --> infinity. Since f_k --> f (by a problem done earlier), it follows that f(n) -->0 as n --> infinity. Since the latter holds, by definition of F it follows that f is contained within. Hence F is closed in E.
This doesn't look right at all. I just wondered what kinds of advice anyone has.
Are you sure you wrote this correctly? It would make more sense to me to say {f in E | f(n) --> 0 as n --> infinity}
Consider two elements of F, f1 and f2, and a scalar c.
1) Show that f1 + f2 is in F. This shows that F is closed under addition.
2) Show that cf1 is in F. This shows that F is closed under scalar multiplication.
Wow I had a few typos. Thanks for clarifying that. I am not sure that this is the idea behind the proof. I need to get some added direction on this one.
What I laid out in post #2 is the standard way of showing that a subset U of a vector space V is in fact a subspace of V. When you say that a subset (F) of a vector space (E) is closed in E, you are saying that the subset is closed under vector addition and closed under scalar multiplication.
Judging by the attempt at a proof, I really think they mean 'closed' here to mean a closed set in the sup norm topology. You want to show if lim as k->infinity |fk-f|=0 and fk are in F then f is in F. I would think about throwing some epsilons around.
Sounds reasonable to me. The bit about vector space threw me off so that I wasn't thinking about "closed" in terms of accumulation points and such.
