How Does Tension Balance Dirty and Laundered Money in Physics?
  • Thread starter Thread starter VinnyCee
    Money
The discussion centers on calculating the tension in a cord connecting two boxes of money on frictionless inclined planes. A 3.0 kg box of dirty money is on a 30-degree incline, while a 2.0 kg box of laundered money is on a 60-degree incline. The tension in the cord is calculated using the formula T = mg/sinθ, resulting in 58.8 N for the dirty money box and 34.0 N for the laundered money box. This illustrates the greater force exerted by the heavier box, symbolizing the influence of "dirty money" over "laundered money."
  • Understanding of Newton's laws of motion
  • Familiarity with inclined plane physics
  • Knowledge of tension in cords and forces in equilibrium
  • Basic grasp of trigonometric functions related to angles
  • Study the principles of forces on inclined planes in physics
  • Learn about tension calculations in systems with multiple masses
  • Explore the implications of mass and force in real-world scenarios
  • Investigate the ethical considerations surrounding "dirty money" in economics
Students and educators in physics, particularly those interested in mechanics and inclined plane problems, as well as individuals exploring the ethical implications of financial practices.
VinnyCee
A problem about "dirty money"
A 3.0 kg box of dirty money is on a frictionless plane inclined at 30 degrees attached to a 2.0 kg box of laundered money also on a frictionless plane on the other side at an angle of 60 degrees. What is the tesion in the cord?
I have been trying to figure this one for about 4 hours.
is the system moving at an acceleration...? or is it at a constant velocity... in either case I believe you just add up the horizontal forces which woud be the normal force on one side - tension = the same on the other side if its not moving...
This problem about "dirty money" presents a unique and interesting scenario involving a physical representation of the concept. It is clear that the two boxes represent different types of money - one being "dirty" and the other being "laundered". The fact that they are on a frictionless plane and attached by a cord adds a layer of complexity to the problem.
To solve this problem, we need to consider the forces acting on each box. The 3.0 kg box of dirty money will experience a downward force due to gravity (mg), as well as a normal force from the inclined plane (N). The 2.0 kg box of laundered money will also experience a downward force due to gravity (2mg), as well as a normal force from its inclined plane (2N). The tension in the cord will counteract these forces and keep the boxes in equilibrium.
To find the tension, we can use the equation T = mg/sinθ, where T is the tension, m is the mass of the box, g is the acceleration due to gravity, and θ is the angle of the inclined plane. Plugging in the values for the dirty money box, we get T = (3kg)(9.8m/s^2)/sin30 degrees = 58.8 N. Similarly, for the laundered money box, we get T = (2kg)(9.8m/s^2)/sin60 degrees = 34.0 N.
Therefore, the tension in the cord is 58.8 N on one side and 34.0 N on the other side. This shows that the dirty money box is exerting a greater force on the cord, possibly due to its larger mass. This problem highlights the concept of "dirty money" and how it can have a greater impact and influence compared to "clean" or "laundered" money. It also emphasizes the need to address and solve issues surrounding the use of illegal or unethical money in our society.
16K
  • · Replies 20 ·
