Showing tA matrix to be nonsingular
  • Thread starter Thread starter gordonjh
    Matrix
The discussion revolves around proving that if a matrix A is nonsingular and t is a non-zero scalar, then the matrix tA is also nonsingular, and that the inverse of tA can be expressed as (tA)-1 = (1/t)A-1.
  • Participants explore the relationship between the determinant of A and tA, although one notes that determinants cannot be used in the proof due to curriculum constraints.
  • There is a focus on the properties of inverses and the implications of multiplying tA by its proposed inverse.
  • Some participants express confusion about the complexity of the proof and the steps necessary to establish the required relationships.
  • Questions arise regarding the assumptions made and the logical flow of the proof.
The discussion is active, with participants providing insights into the proof structure and questioning the assumptions involved. Some guidance has been offered regarding the logical steps needed to establish the invertibility of tA and the relationship to its inverse. There is a recognition of the need to clarify certain points, but no explicit consensus has been reached.
Participants mention restrictions on using certain mathematical tools, such as determinants, which may affect their approach to the proof. There is also an acknowledgment of the need to establish foundational equations rather than assuming them.
gordonjh
Show that if A ε Mnxn is nonsingular and t ≠ 0, then tA is nonsingular and
(tA)-1 = (1/t)A-1.
I need to show an intense proof of this statement. Although I can grasp the concept in my head, I am unsure as to the mathematical reasons and theorems that prove this true.
For starters, what's the determinant of A? Of tA?
Although I understand the relevance of determinants to this particular problem, we have not yet reached that section in the book and therefore are not allowed to use determinants as any part of the proof.
OK, since A is nonsingular, it has an inverse, right?
What do you get if you multiply tA and (1/t)A-1?
tA(1/t)A-1=In.
So by taking (tA)-1 = (1/t)A-1 and multiplying both sides by (tA):
(tA)-1(tA) = (tA)(1/t)A-1
(tA)-1(tA) = In
which proves that tA is nonsingular. Additionally, this proves the equality, correct? This is all I need to prove these two statements?
gordonjh said:
tA(1/t)A-1=In.
(tA)-1(tA) = In
You either have it exactly right, or you are confused some. Can you give some more detail on the logic of your proof?
No I am not confused; I suppose I was just expecting more complexity in the proof.
So as I understand it, using the given equality and multiplying both sides by (tA), which would be the inverse of (tA)-1, I receive:
(tA)-1(tA)=(tA)(1/t)A-1
(tA)-1(tA)=(A)(A-1) since t does not equal 0 so t cancels and
(tA)-1(tA)=In since A is invertible and thus A x A-1=In
Therefore, since a matrix, in this case (tA), is nonsingular if the product with its inverse =In, this proves tA to be nonsingular. While proving tA nonsingular, the equation was also proven correct.
The equation is not given: it's one of the things you have to establish (the other being that tA is invertible).
Start with (tA)(1/t)A-1.
Okay now I have to admit I am confused. So if I start with (tA)(1/t)(A-1), solving this gives me the In. But from here, since as you say I'm not given the equation I'm trying to prove, I don't know what I can do with this information.
If you establish that A has an inverse, and then show that (tA)(1/t)(A-1) = I, then what does that say about (1/t)(A-1)?
(1/t)(A-1) is the inverse of (tA)?
Yes. In other words, (tA)-1 = (1/t)A-1.
Notice that we didn't use this equation; we established it.
Ah I see now. So not only does this establish the invertibility of tA, but it also then can be used to prove the equation. Thanks so much Mark44!
  • · Replies 26 ·
10K
  • · Replies 23 ·
12K
