Why Are Electric Field Lines Straight Around Relativistic Electrons?
The discussion centers on the behavior of electric field lines around relativistic electrons, particularly why these lines appear straight despite the motion of the charge. Participants explore concepts related to special relativity, field propagation, and the implications of constant versus accelerated motion.
  • Some participants note that electric field lines around a relativistic electron appear straight and cluster around a plane perpendicular to the direction of motion, raising questions about the implications of this for predicting the charge's future location.
  • Others suggest that the behavior of electrons in atomic orbits may relate to wave properties and spacetime dilation, indicating a complex interaction between position and motion.
  • One participant mentions that for a slower electron, the field lines would also appear straight but with negligible bending, suggesting that speed influences the perception of field line behavior.
  • It is proposed that if the charge were accelerating, the field lines would bend, contrasting with the straight lines observed in uniform motion.
  • Some participants discuss the concept of retarded fields, indicating that the field lines' straightness is contingent on the charge having moved at constant velocity since an infinite past, and that changes in velocity would introduce kinks in the field lines.
  • There is a question about whether the field lines are bent even in constant speed scenarios, with references to how observers perceive the field based on their relative motion to the charge.
  • One participant draws an analogy with the Earth's magnetic field, questioning how motion relative to a magnetic field influences experiences like the Hall voltage, suggesting a nuanced understanding of field interactions.
Participants express multiple competing views regarding the nature of electric field lines in relation to relativistic motion, with no consensus reached on whether the lines are truly straight or bent under constant motion. The discussion remains unresolved on several points, particularly regarding the implications of retarded fields and observer perspectives.
The discussion highlights limitations in understanding the propagation of electric fields, the assumptions about observer perspectives, and the complexities introduced by acceleration versus uniform motion. There are unresolved mathematical aspects related to the retarded field equations.
shoestring
Imagine an electron in uniform motion moving at a speed near the speed of light.
Pictures I've seen of the electric field around such a charge look like this one from wikipedia:
The field lines are straight, but clustering around the plane perpendicular to the direction of motion.
Why are the lines perfectly straight? It looks to me as if that means that the field can predict the future location of the charge. At a distance ct from the charge, why don't the field lines point to the location where the charge was t seconds earlier?
One thing that really stuck out with me was electrons orbiting around an atom will vanish or jump at orbits that the wavelength is a distance where the previous orbit of the electron will not match up at a full wavelength. It is if they know the round trip will not allow them to wave at the same locations every time around so then they vanish and jump to different valence shells. They only like orbitals where the circumfrance is divisable by a full wave length.
So, I would blame it on spacetime dialation... It gets fuzzy around there, but I think contracted worldlines are involved there for the particles themselves. They know exactly where they are and how fast they are moveing they just don't like to share that knowledge with us :P
I could have asked the same question for a much slower electron, but in that case the effect would have been negligible. For a slow electron the field lines would look very straight even if they were slightly bent.
Short Answer: all motion is relative. If the charge was accelerating, then the lines would bend.
The diagram is valid if the charge has always been moving at constant velocity since [itex]t=-\infty[/itex], so that the information about its motion has had infinite time to propagate.
If the charge's velocity changes, the lines won't be straight. There will be kinks that propagate outward.
shoestring said:
...The field lines are straight, but clustering around the plane perpendicular to the direction of motion...Why are the lines perfectly straight? It looks to me as if that means that the field can predict the future location of the charge. At a distance ct from the charge, why don't the field lines point to the location where the charge was t seconds earlier?
Good question. It's the difference between a 'present position' presentation of field lines (as shown in your borrowed illustration), and a retarded position presentation. As you have figured, the charge location from the point where the field originates will be a function of distance from the moving charge. The further out the observer, the further back (to the left) the charge must have been at the time it acted as a source of field wrt that observer. From that retarded field perspective (indispensable when treating accelerated motion for say charge oscillating in an antenna), the lines are not straight, even for constant speed! Remember that in SR a charge moving at say +v in your frame is equivalent to you moving at -ve past a 'stationary' charge, and so it is 'natural' to expect a relativistic length contraction of field lines along the axis of motion. Accelerated motion on the other hand will not give you reciprocal effect - acceleration in your frame past a non-accelerated charge will give a different result than vice versa.
Is that the right way to treat it, meaning that the field lines are actually bent for constant speed too? Or does the field "travel with" the charge as long as it is in uniform motion?
For example, I've heard it said that the Earth's magnetic field rotates with the earth, so that as long as I'm stationary relative the surface of the earth, I'm not "travelling through" the Earth's magnetic field, even though the Earth is rotating. Meaning that a stationary human body shouldn't experience a Hall voltage due to the Earth's rotation and magnetic field, despite moving at a speed of order 1000 km/h. Sitting on a plane, on the other hand, moving at a similar speed relative the earth, could result in a Hall voltage. Or perhaps I've got it completely wrong ...?
Bent or not bent comes down to 'point of view'. The 'straight lines' picture is what you get when all 'stationary' observers (field points) are taking a 'snapshot' of the source charge's field at the same instant, regardless of how distant each are from the source charge. It's as though the field propagated instantly, a viewpoint not possible if acceleration occurs. As discussed previously, that means the charge's retarded position (ie, the point it was when the field emanated) is in general different for those observers. These retarded field lines are in consequence not straight, but for constant straight line motion happen to arrive at just the right moment for each observer to give the 'illusion' of emanating as straight lines from a single point. The full retarded field equations can be studied at eg: http://www.physics.usyd.edu.au/~kuncic/lectures/HEA_L5.pdf (eq'n (4), p44 there) Omit the acceleration parts and you will find the electric field equation for a charge in uniform motion - doesn't give straight lines. But remember this is a retarded time usage, mostly intended to deal with accelerated charge motion.
I doubt the Earth's magnetic field can be considered locked to the Earth's rotation (believed generated by an internal dynamo in the core that circulates in a complex way). Best thought of as non-rotating, and you are moving through. Very weak effect that basically gets canceled out from gross electrical neutralization in Earth's crust, atmosphere etc. No danger of frying cell-phones etc! Can be fascinating to study what amounts to a Faraday Disk type of effect: http://en.wikipedia.org/wiki/Faraday_paradox
  • · Replies 20 ·
  • · Replies 73 ·
  • · Replies 44 ·
