What is the Helmholtz Decomposition of a Vector Field?
The Helmholtz Decomposition states that any vector field H can be expressed as the sum of an irrotational function F and a solenoidal function G. In this discussion, the vector field H(r) = x²yi + y²zj + z²xk is analyzed, leading to the equations F = -∇Ψ and G = ∇×A. The divergence of H was calculated, resulting in the equation ∇²Ψ = -2xy - 2yz - 2zx. A proposed solution for Ψ is -xyz(x+y+z), which effectively decomposes H into its components.
  • Understanding of vector calculus, specifically divergence and curl operations.
  • Familiarity with Helmholtz's theorem and its implications in vector field analysis.
  • Knowledge of Laplace's equation and methods for solving it.
  • Experience with irrotational and solenoidal vector fields.
  • Study the derivation and applications of Helmholtz's theorem in vector calculus.
  • Learn techniques for solving Laplace's equation in three dimensions.
  • Explore methods for finding irrotational and solenoidal components of vector fields.
  • Investigate the properties of curl and divergence in the context of fluid dynamics.
Students and professionals in mathematics, physics, and engineering who are working with vector fields and require a deeper understanding of the Helmholtz Decomposition and its applications.
Zebrostrich
Let H(r) = x[tex]^{2}[/tex]yi + y[tex]^{2}[/tex]zj + z[tex]^{2}[/tex]xk. Find an irrotational function F(r) and a solenoidal function G(r) such that H(r) = F(r) + G(r)
From Helmholtz's theorem, any vector field H can be expressed as:
H = -[tex]\nabla[/tex][tex]\Psi[/tex] + [tex]\nabla[/tex]xA
So then:
F = -[tex]\nabla[/tex][tex]\Psi[/tex]
and G = [tex]\nabla[/tex]xA
Taking the divergence of H(r) = F(r) + G(r), I obtained (since the Divergence of G is zero)
[tex]\nabla[/tex][tex]^{2}[/tex][tex]\Psi[/tex] = - 2xy - 2yz - 2zx
I really have no idea how to solve this equation. If I took the curl, I would have an even more complicated system. I found out a solution to this equation, but merely by guessing. That would be [tex]\Psi[/tex] = -xyz(x+y+z), and from there I found the two vector fields. However, that does not seem sufficient enough. Is there a better way to approach this problem that I am missing?
I don't think so. If you can guess a solution to Laplace's equation, which you did, you are way ahead of the game. I think that's the way you were intended to solve it. The problem was rigged that way. Great job.
  • · Replies 26 ·
  • · Replies 20 ·
