Topology: Finite Complement & Defining Limit Points
  • Thread starter Thread starter doodlepin
    Topology
The discussion centers on the finite complement topology defined on a set X, where the collection of open subsets O satisfies that the complement X - O is either finite or the entirety of X. The participants establish that in the case of an infinite set X, if subset A is finite, it has no limit points, while if A is infinite, every point in X is a limit point. The proof hinges on the properties of open sets and their intersections with subsets, clarifying the conditions under which limit points exist.
  • Understanding of topology concepts, specifically finite complement topology.
  • Familiarity with limit points in topological spaces.
  • Knowledge of set theory, including subsets and complements.
  • Basic proof techniques in mathematics, particularly in topology.
  • Study the properties of finite complement topology in more depth.
  • Learn about discrete topology and its implications for limit points.
  • Explore examples of limit points in various topological spaces.
  • Investigate the relationship between open sets and their complements in topology.
Mathematicians, students of topology, and anyone interested in the foundational concepts of limit points and topological spaces.
doodlepin
Question is: X is a set and tau is a collection of subsets O of X such that X - O is either finite or all of X. Show this is a topology and completely described when a point x in X is a limit of a subset A in X.
I already proved that this satisfies the conditions for defining a topology (called the finite complement topology) But I am having a lot of trouble with defining when a point is a limit. I know that any open subset (defined by tau) containing such a limit point must have a non-empty intersection with A for it to be a limit point.
I have tried considering multiple cases: I know if X is finite then it is the discrete topology and therefore no limit points exist. So the non trivial case if when X is infinite.
Now, if A is finite then for any open subset containing x, O, the complement with A would obviously be finite so therefore non empty?
I'm sort of stuck and could use a nudge in some helpful direction.
You are correct in saying that the only case you need to find out is when X is infinite.
Now there are two more cases to consider:
1) A is finite: I claim that A has no limit points in this case. Hint: consider X/A
2) A is infinite: I claim that every point is a limit point in this case. Take U open, then X/U is finite. So it can not happen that [tex]A\subseteq X\setminus U[/tex]. I'll let you complete the proof...
wow you are totally right. Thank you so much. Sometimes you start thinking too hard about something and you start to over analyze it. :)
  • · Replies 58 ·
