Rank of Matrices in Mathematica
The discussion revolves around finding the minimal rank of a matrix in Mathematica when the matrix contains symbolic parameters. Participants explore methods to determine the rank while considering the dependencies between the parameters and the implications of assuming certain parameters are non-zero.
  • One participant seeks a way to determine the minimal rank of a matrix with symbolic parameters, suggesting that Mathematica's default behavior assumes all parameters are independent.
  • Another participant proposes using the concept of minors to find the rank, referencing Mathematica's documentation and providing a script to test for zero minors.
  • Some participants note that Mathematica's output reflects the general case, where the rank could vary depending on the values of the parameters, and that this may not be useful for specific cases.
  • There is a suggestion that the minimal rank could be computed under the assumption that at least one parameter is non-zero, which aligns with the original poster's intent.
  • One participant expresses difficulty in ensuring the program does not consider certain parameters as zero, seeking advice on modifying the code to enforce this condition.
  • Another participant offers a method to solve for relationships between the matrix entries, indicating that this could lead to a rank of 1 under specific conditions.
  • There is a discussion about the implications of different parametrizations of the same matrix space and how they may yield different minimal ranks.
Participants generally agree on the challenges of determining the minimal rank with symbolic parameters, but multiple competing views remain regarding the best approach to achieve this. The discussion does not reach a consensus on a definitive solution.
Limitations include the assumptions about parameter independence and the potential for multiple parametrizations leading to different ranks. The discussion highlights the complexity of handling symbolic matrices in Mathematica.
Newtime
The problem: I need to find the (minimal) rank of some matrix which is basically all parameters. For example, when i ask for the rank of [tex]\begin{pmatrix} a& b& c \\ d& e& f \\ g& h& i \end{pmatrix}[/tex], I get 3. I would like to get 1, since (excluding the possibility of a matrix of all 0's) it could be the case that row two is a multiple of row one, etc. Is there anyway to do this? If not, does anyone have any idea for a good script that could accomplish this?
I know Mathematica is advanced enough to recognize things like multiple of rows on its own. For instance, if I input a general rank one matrix [tex]\begin{pmatrix} s_1t_1& s_1t_2& s_1t_3 \\ s_2t_1& s_2t_2& s_2t_3 \\ s_3t_1& s_3t_2& s_3t_3 \end{pmatrix}[/tex], I get 1.
Warning: I'm not an expert in linear algebra... there's probably a better way to solve this problem.
The Mathematica documentation page on http://reference.wolfram.com/mathematica/ref/Minors.html#ES_3_" says
The rank is the largest k for which Minors[mat, k] contains nonzero entries:
And I think that this might be a [STRIKE]good[/STRIKE] possible way to go.
As you said in your post:
Code:
In[1]:= mat={{a,b,c},{d,e,f},{g,h,i}};
        MatrixRank[mat]
Out[2]= 3
Then you can test if a given matrix of minors has a zero solution using something like
Code:
testZeroMinors[mat_, rnk_, dom_: Complexes] := Not[{} === FindInstance[
  And[And@@Thread[Minors[mat, rnk] == 0], Or@@Thread[Variables[mat] != 0],
      Element[Variables[mat], dom]], Variables[mat]]]
Then the minimal rank (assuming that not all free parameters are zero) can be found using
Code:
minimalRank[mat_, dom_:Complexes] := Module[{i = 1}, While[!testZeroMinors[mat, i, dom], i++]; i-1]
We can test this using some simple examples:
Code:
In[5]:= minimalRank[{{a,b,c},{d,e,f},{g,h,i}}]
        minimalRank[{{a,0,0},{b-I,0,0},{0,0,1}},Reals]
        minimalRank[{{a,0,0},{b-I,0,0},{0,0,1}},Complexes]
        minimalRank[{{a,0,0},{0,1,0},{0,0,1}}]
Out[5]= 1
Out[6]= 2
Out[7]= 1
Out[8]= 3
Code:
In[9]:= mat2={{s1},{s2},{s3}}.{{t1,t2,t3}}
Out[9]= {{s1 t1,s1 t2,s1 t3},{s2 t1,s2 t2,s2 t3},{s3 t1,s3 t2,s3 t3}}
In[10]:= MatrixRank[mat2]
         minimalRank[mat2]
Out[10]= 1
Out[11]= 1
If you give Mathematica 9 different symbols, a thru i, it makes the assumption they are 9 independent quantities.
Usually, the most general solution to the problem (which in your case would be "well, the rank could be anything between 0 and 3 inclusive, depending on the values of the parameters") is not very useful. That's why Mathematica doesn't work that way.
You more or less answered your own question with your second example. If you define some relationships between the entries in the matrix, Mathematica will use all the infomation you gave it.
Note, in your the second example, it is also considering the 6 parameters to be independent. For example it is not considering special cases like s1 = s2 = s3 = 0, or t1 = t2 = t3 = 0.
Hi AlephZero,
I think that the OP knows this. He wanted a function that gives the minimal rank a matrix could have assuming that the free parameters are all independent and in some sense "non-trivial". Mathematica gives the result that holds for almost all if the parameter space. (i.e. up to a set of measure zero).
I gave a solution that gives the minimal rank assuming that at least one of the free parameters is nonzero - which is close to what the OP wanted. The conditions in the FindInstance can be tweaked to the case that he's actually interested in.
Thanks AlephZero and Simon Tyler for your help, the code runs quite well. However, it is not quite what I need, but I think this is mainly due to my inability to explain what I need the computer to actually do.
For example, I'm running test right now where the minimalRank is given to me as 1 for arbitrary parameters a,b. However, if I plug in ANY values for these numbers, I get the minimalRank as 2, as I expect. (I can prove by hand that indeed a and b are non-zero, but proving by hand that the minimalRank is two even with this knowledge is much more difficult, hence my desire for computer aid.) Is there a way to hard-code the program so that it doesn't consider the possibility of a or b being 0? I would think this would be very simple to do, but my programming knowledge is extremely limited.
Thanks again for the help.
Would something like this help you?
In[31]:= m={{a,b,c},{d,e,f},{g,h,i}};
Solve[m[[1]]==j*m[[2]]&&m[[2]]==k*m[[3]],Union[m[[1]],m[[2]]]]
Out[32]= {{a->g j k,b->h j k,c->i j k,d->g k,e->h k,f->i k}}
In[33]:= m/.First[%]
Out[33]= {{g j k,h j k,i j k},{g k,h k,i k},{g,h,i}}
In[34]:= RowReduce[%]
Out[34]= {{1, h/g, i/g}, {0, 0, 0}, {0, 0, 0}}
and so this arbitrary matrix can have rank 1, but only if some of your variables are nonzero and others can take values to make this rank 1.
Note that Union is collecting the variables in the subsequent rows of the matrix for Solve and this simple method won't work if elements of your rows consist of more general expressions, but perhaps you can adapt this to whatever form your matrix actually has.
Furthermore, I don't believe what is done above is necessarily a general solution to your problem. I might imagine a case where row 2 is really independent and only rows 1,3,4,... can be "solved away" to give you a rank of 2. I've thought about this a bit, but don't see an elegant solution to the problem at the moment.
At the moment the code assumes that at least one of the variables is non-zero
If you want none of your variables to be zero, then replace
Code:
with
Code:
And@@Thread[Variables[mat] != 0]
Don't forget though, you can have many different parametrizations of the same space of matrices:
eg the span over the reals of {{a, 0, 0}, {0, b, 0}, {0, 0, 1}}
is the same as the span over the reals of {{a, 0, 0}, {0, a-b, 0}, {0, 0, 1}}
But this will be given different minimal ranks by the program.
So, think carefully about you matrix parametrizations and the questions you ask.
