Why is Voltage b/w 220 & 330 Olm Resistors 0V?
The voltage between the 220 ohm resistor and the 330 ohm resistor in a series circuit is 0V due to the presence of a 0 ohm conductor connecting them. The current flowing through the circuit is calculated as 9.8 mA, derived from the total resistance of 1020 ohms with a 10V source. The voltage across the 220 ohm resistor is 2.157V, and across the 330 ohm resistor, it is 3.234V. Since there is no potential difference across the 0 ohm conductor, the voltage measured between these two resistors is zero.
  • Understanding of Ohm's Law
  • Basic knowledge of series circuits
  • Familiarity with resistor values and calculations
  • Concept of current flow in electrical circuits
  • Study Ohm's Law in detail for practical applications
  • Learn about series and parallel circuit configurations
  • Explore the concept of equivalent resistance in circuits
  • Investigate the effects of short circuits on voltage measurements
Electrical engineering students, hobbyists working with circuits, and anyone interested in understanding voltage measurements in series resistor configurations.
sirfederation
ok the question I have is why is the voltage between the 220 olm resistor and the 330 olm resistor 0 V.
All resistors in the image are in series so Is=I1=I2=I3
Is = 10/1020 (v/olm) = .0098 or 9.8 mA
V(subscript220)= 220*9.8 mA = 2.157 V (this is the voltage between the DC source and the 220 olm resistor)
V(subscript330) = 330 * 9.8 mA = 3.234 V (this is the voltage between the 330 olm and the 470 olm resistor)
V(subscript470) = 470 * 9.8 mA = 4.606 ( I have to add 3.234 to 4.606 to find the voltage between the DC source and 470 which is 7.84 V)
I am taking the ground up above the the 330 olm resistor.
Ok now I am not sure but I think the reason why the voltage across the 220 to the 330 olm resistor is zero is because I have to make a open circuit in that area which means that no current is actually passing through the wire since current takes the path of least resistance.
be careful how you word your question!
the answer to this question is that you are measuring the voltage on a 0 ohm conductor between r220 & r330
  • · Replies 19 ·
