Boosting Induction Motor Speed: Tips and Techniques
The discussion revolves around methods to increase the speed of induction motors beyond the synchronous speed determined by the frequency of the power supply. Participants explore various techniques and tools that could potentially allow for higher operational speeds.
  • Exploratory, Technical explanation, Debate/contested
  • One participant states the formula for synchronous speed and notes the limitation of achieving only 3000 rpm with a 2-pole induction motor on a 50 Hz supply.
  • Another participant suggests using an inverter to increase the frequency as a method to achieve higher speeds.
  • A different approach is proposed involving the use of a gearbox or pulleys to mechanically increase speed.
  • A later reply questions whether using a Variable Frequency Drive (VFD) is a viable method for this purpose.
Participants present multiple competing views on how to achieve higher speeds, with no consensus reached on the best method.
Participants do not clarify the limitations or assumptions regarding the use of inverters, gearboxes, or VFDs, nor do they address potential impacts on motor performance or efficiency.
Individuals interested in electrical engineering, motor control, or mechanical systems may find the discussion relevant.
neduet
Hello friends
Synchronous speed = 120f/p p is number of pole pairs OK
So in my country 50hz 3- phase source is provided so that I can only archived 3000 rpm speed by 2 pole induction motor… how I can archived more then 3000Rpm ( Is that possible or not ) if yes then how ?
thanks
You'd have to use an inverter to increase the frequency.
Or gear box or pulleys.
is That by VFD ?
  • · Replies 31 ·
14K
9K
