The webpage title could be: Calculating the Force of Air on Your Head
  • Thread starter Thread starter Deeviant
    Air Force Head
The discussion revolves around calculating the force exerted by air on the surface area of a person's head, specifically using the relationship between pressure, force, and area. The original poster presents a scenario involving atmospheric pressure and the surface area of the head.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to apply the formula P = F/A to find the force, expressing confusion over unit conversions and the application of atmospheric pressure. Some participants suggest alternative unit systems and question the consistency of unit conversions. Others express concerns about potential mistakes in the calculations and the interpretation of the problem.
There is mention of needing the answer in Newtons and the challenges faced with unit conversions, particularly between centimeters and meters. The original poster expresses frustration over the simplicity of the question compared to others they have solved.
Deeviant
Ok I have the following question:
If the top of your head has a surface area of 113 cm2, what is the weight of the air above your head?
I'm not sure what I am doing wrong. I used the P = F/A. Solved for F to get F= P/A. I'm assuming the question is asking me for the force of the air on my head.
I'm using a figure of 1.013X10^5 Pa for atmospheric pressure, and I converted cm to meters then divide the P(101300 Pa) by A(1.13) meters, and webassign told me to go fish.
I'm sure I'm doing something wrong, just not sure what.
Hmm. Try using kPa or keeping the area value in sq. cm. That might work.
Hmm well I did make one stupid mistake when solving for F, F= P*A. Although I still can't seem it get it right. I'm sure its something to do with units, I have been having huge problems getting the units right lately, sometimes they just don't make sense.
It wants the answer in N. So I would assume I have to convert cm to m since N is in meters. But I'm just not having any luck today with this question, the silly thing is this is the first question and I have answer most of the harder ones already, just can't get this one.
still need help..
1 m = 100 cm
[tex](1\ m)^2 = (100\ cm)^2[/tex]
[tex]1\ m^2= 1X10^{4}\ cm^2[/tex]
[tex]113\ cm^2= \frac{113}{10^4} = 0.0113\ m^2[/tex]
[tex]F=P*A=1.013X10^5*0.0113=1145\ N[/tex]
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 60 ·
