Can a human breathe in an atmosphere that has a gas other than nitrogen?
The discussion revolves around the feasibility of human respiration in atmospheres composed of gases other than nitrogen, particularly in extraterrestrial environments. Participants explore the implications of varying inert gases and oxygen levels on human breathing and physiological effects.
  • Some participants inquire whether humans can breathe in an atmosphere with 21% oxygen and a different inert gas, questioning the role of nitrogen in this context.
  • There is a suggestion that a planet with 20% oxygen and 80% helium could be breathable, with the caveat that helium would affect voice pitch.
  • Another participant emphasizes the importance of oxygen's partial pressure, noting that while 16% is the minimum to sustain consciousness, higher levels can be toxic over time.
  • Concerns are raised about helium's lower density potentially leading to an imbalance in oxygen levels at low altitudes, making it unsuitable for long-term habitation.
  • Some participants speculate on the potential of neon as an inert gas, suggesting it might mix well with oxygen, but they acknowledge uncertainty regarding its effects on lifeforms.
  • Questions are posed about the visual characteristics of a neon-oxygen atmosphere and the implications for Earth life and hypothetical native lifeforms.
Participants express differing views on the suitability of various gases for human respiration in extraterrestrial atmospheres. There is no consensus on which combinations would be viable or how they would affect human physiology.
Discussions include assumptions about gas behaviors, the effects of partial pressures, and the stability of isotopes in potential atmospheres. Limitations in knowledge about extraterrestrial conditions and their implications for human life are acknowledged.
Individuals interested in astrobiology, planetary science, and the physiological effects of different atmospheric compositions may find this discussion relevant.
FtlIsAwesome
Dry air contains roughly (by volume) 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases. Air also contains a variable amount of water vapor, on average around 1%.
From Wikipedia, Earth's Atmosphere
Is possible for a human to breathe in an atmosphere that contains 21% oxygen, but has a different inert gas other than nitrogen?
Also, how do different levels of oxygen affect us?
Biology news on Phys.org
AlephZero said:
See http://en.wikipedia.org/wiki/Breathing_gas for information on both questions.
This page does have some information I was looking for.
I was thinking of extraterrestrial planets, at roughly 1 atm pressure.
So humans could breathe on a planet with 20 percent oxygen and 80 percent helium? Humans' voices would be higher pitched on this planet.
A planet with neon instead wouldn't change someone's voice.
The important parameter is the partial pressure of oxygen in the mixture. Helium has a much smaller atomic weight from nitrogen, so it depends what you mean by "20%". The safe range of oxygen partial pressures is quite small. The minimum to sustain consciousness is about 16%, but too much for moderate lengths of time (e.g. a few hours) is also toxic.
For example with current space technology, astronauts wearing space suits in a vacuum breathe pure oxygen at 0.2 atm pressure whcih is equivalent to the 20% oxygen in the standard Earth atmosphere, but the reduced pressure makes it easier to design a flexible space suit.
Helium would not work. In a short time the difference in density would cause there to be too much oxygen at low altitudes as the helium tended to escape from the planet...
Oxygen/nitrogen works cause they have close to the same mass, oxygen about 16 and Nitrogen about 14. But Helium is about 4 and is, as they say, lighter then air.
Now thinking about it, I could've gotten a terse answer for the title question from a Google search.
Really what am asking about is extraterrestrial atmospheres and their theoretical properties, so would this post be better suited to a different category like General Astronomy?
Good point.
Neon might work because its number of protons+neutrons is 20.
Some isotopes that are uncommon on Earth, but stable: Ne-21, Ne-22, O-17, O-18, N-15
Some combinations of these isotopes might mix better and therefore have a livable atmosphere, but it probably doesn't matter much.
What would the color of a neon-oxygen atmosphere be, assuming the sun was a G class? Also, how would it affect lifeforms from Earth and how would native lifeforms function?
15K
24K
90K
